caddy 2.1.1
/usr/bin/caddy run --environ --config caddy.json
Docker
CMD ["caddy", "run", "-config", "/etc/caddy/caddy.json"]
"tls_connection_policies": [
"match": {
"sni": [
"*.edjx.test"
"certificate_selection": {
"all_tags": [
"validate"
"client_authentication": {
"trusted_ca_certs":["{env.TRUSTED_CAS}"],
"mode": "verify_if_given"
env var is present.
but seems like it is not configured to use env for this trusted_ca_certs
field.
Error Logs:
run: loading initial config: loading new config: loading http app module: provision http: server domainserver: setting up TLS connection policies: connection policy 0: building standard TLS config: configuring TLS client authentication: parsing certificate: illegal base64 data at input byte 0
