How to use Docker secrets with Caddy
When running services in Docker, storing secrets (like API keys) directly in environment variables can expose them when inspecting the container. A safer approach is to use Docker Secrets, which keeps sensitive values outside of your runtime environment.
This guide shows how to integrate Docker Secrets with Caddy, making secrets available as environment variables inside the container without exposing them.
Define Your docker-compose.yml
We’ll configure a caddy service that builds from a custom Dockerfile and mounts a secret called api_key.
    build: .
    cap_add:
      - NET_ADMIN
    secrets:
      - api_key
      - data:/data
      - config:/config
      - caddy
  data:
  config:
    external: true
secrets:
  api_key:
    environment: API_KEY
This declares the api_key secret, which we’ll inject into the container. It content comes from the host environment variable API_KEY.
Create a Custom Dockerfile
Caddy itself doesn’t automatically load secrets from /run/secrets/, so we need a small helper script to export them as environment variables.
FROM caddy:2-alpine
COPY ./export_secrets /usr/sbin/export_secrets
RUN chmod +x /usr/sbin/export_secrets
ENTRYPOINT ["/usr/sbin/export_secrets"]
CMD ["caddy"]
In our Dockerfile we copy the script, make it executable, and set it as the container entrypoint.
Write the export_secrets Script
This script loops over all files in /run/secrets/, converts their filenames to uppercase, and exports them as environment variables before launching Caddy.
#!/bin/sh
set -e
# Export all secrets in /run/secrets as uppercase env vars
for secret_file in /run/secrets/*; do
  if [ -f "$secret_file" ]; then
    secret_name=$(basename "$secret_file")
    env_var_name=$(echo "$secret_name" | tr '[:lower:]' '[:upper:]')
    export "$env_var_name"="$(cat "$secret_file")"
  fi
done
# Execute the container’s main process
exec "$@"
For example, a file named /run/secrets/api_key becomes the environment variable API_KEY.
Use the Secret in Caddyfile
Now you can reference the secret as an environment variable in your Caddyfile:
  some_module {
    api_key {env.API_KEY}
Run the Container
Start the container by providing the secret, add a space before the secret to not safe this command into your bash/zsh history:
$  API_KEY='super_secret!' docker compose up -d
Or use any Secret Manager with a CLI to get the secret.
Of course, this would be even nicer if implemented as a Caddy module, but this is out of scope right now.
Thank you! I’ve move your post to the Wiki category.
Can you help me understand please? If you’re converting secrets into the environment variables, how does that differ from just using env_file?
    env_file: "caddy.env"
By the way, you don’t need to parse the secrets file and load them into env vars. You can use the placeholder {file./path/to/secret} directly.
Sorry, answering my own question after a quick test.
docker-compose.yaml:
  caddy_build:
    build: .
    container_name: caddy_build
    env_file: ./caddy_env_file
    secrets:
      - caddy_secret
secrets:
  caddy_secret:
    file: ./caddy_secret_file
Dockerfile:
FROM caddy:2-alpine
CMD [ "caddy", "run", "--config", "/etc/caddy/Caddyfile", "--adapter", "caddyfile" ]
caddy_env_file:
CADDY_ENV=test_value
caddy_secret_file:
super_secret!
$ docker inspect caddy_build | jq '.[] | .Config.Env'
  "CADDY_ENV=test_value",
  "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
  "CADDY_VERSION=v2.10.2",
  "XDG_CONFIG_HOME=/config",
  "XDG_DATA_HOME=/data"
$ docker exec -ti caddy_build printenv
HOSTNAME=69c78f1d017f
TERM=xterm
XDG_DATA_HOME=/data
HOME=/root
$ docker exec -ti caddy_build strings /proc/1/environ
SHLVL=1
HOME=/root
XDG_DATA_HOME=/data
CADDY_SECRET=super_secret!
PWD=/srv
So, while env_file shows up directly in .Config.Env, the environment variables created from secrets need a bit more digging to find. That’s the difference.
My question was kind of silly, but at least it gave me an excuse to poke around a bit :slight_smile:
this is the official and better approach.
Thank you I wasn’t aware of this :+1:
