How to use different schemes for load balancing in Caddy?
I need to use Caddy for reverse proxy and load balancing. After configuring it, it prompts that the scheme must be the same. I have two target addresses: 127.0.0.1, which is located on the local machine, and another one is a domain on remote machine, which is on another server.
When I remove the “http://” prefix from “http://127.0.0.1:4020”, Caddy can start normally, but when I try to access it, I get a 502 error and a TLS error. If I add the prefix back, it prompts that the scheme must be the same. I’ve tried many methods, but none of them work. I couldn’t find any relevant solutions on Google, and the answers provided by ChatGPT didn’t work either.
So what should I do? Thank you very much!
reload: adapting config using caddyfile: parsing caddyfile tokens for 'reverse_proxy': Caddyfile:28 - Error during parsing: for now, all proxy upstreams must use the same scheme (transport protocol); expecting 'http://' but got 'https://'
v2.4.6
binary file.
./caddy start
aaa.com443 {
    reverse_proxy {
        to http://127.0.0.1:4020
        to https://The domain name pointing to another server.
        lb_policy random
It’s not possible to load balance between upstreams with different transport requirements. They must both be HTTP or both be HTTPS.
