How to use Caddy for certificates only, without binding to ports?
I want to disable http and https and only use caddy for certificate renewal using DNS challenges.
I’m just not clear on what the config should look like.
N/A
curl https/webi.sh/caddy | sh
source ~/.config/envman/PATH.env
caddy run --config ./Caddyfile
N/A
N/A
N/A
This is what I’m using right now (using it for 3CX, hence the RSA keys):
    auto_https disable_redirects
    # I think I don't need this since the redirect is disabled?
    http_port 61080
    https_port 61443
    default_bind 127.0.0.1
example.com {
        dns lego_deprecated dnsimple
        key_type rsa4096
N/A
There’s no way to do that with a Caddyfile. Use a JSON config for that.
You can adapt your config to JSON, and then just delete the whole http app. Only the tls app is needed.
