How to specify path for reverse proxy
I’m using docker compose with asp net app and caddy
My config:
  "handle": [
      "handler": "subroute",
      "routes": [
          "handle": [
              "handler": "reverse_proxy",
              "upstreams": [
                  "dial": "constests:4000/contest/examplecontest"
  "match": [
      "host": [
        "examplecontest.com"
  "terminal": true
I want that if a user goes to the examplecontest.com site it will be proxied through constests:4000/contest/examplecontest, but it doesn’t seem to work.
How can this be fixed? The point is that I need to dynamically bind domains to a specific path via the api on the site
"msg":"dial tcp: lookup contest/examplecontest: no such host"
"err_trace":"reverseproxy.statusError (reverseproxy.go:1248)"
Via Docker compose
Docker
	"admin": {
		"listen": ":2019"
	"apps": {
		"http": {
			"servers": {
				"srv0": {
					"listen": [
						":443"
					"routes": [
							"handle": [
									"routes": [
											"handle": [
													"upstreams": [
															"dial": "contestgenerator:5000"
							"match": [
									"host": [
										"contestcreator.com"
							"terminal": true
							"handle": [
									"routes": [
											"handle": [
													"upstreams": [
															"dial": "contestgenerator:5000/contest/MZVPC_1234:80"
							"match": [
									"host": [
							"terminal": true
As I said on How to specify path for reverse proxy · Issue #5817 · caddyserver/caddy · GitHub you need to use the rewrite handler.
I tried something like
  "handle": [
      "routes": [
          "group": "group1",
          "handle": [
              "handler": "rewrite",
              "uri": "contestgenerator:5000/contest/examplecontest"
  "match": [
      "host": [
  "terminal": true
But it doesn’t work, when i go to examplecontest.com it’s return 200 ok with no content
Rewrites don’t take a full URL, it only takes a path+query. Please read the documentation.
And you can’t only do a rewrite, you still need to proxy afterwards. Handlers are a chain.
Is there any particular reason you’re using a JSON config? You’d probably have an easier time with a Caddyfile.
Either way, you can write a Caddyfile for what you want, then run caddy adapt --pretty to get the equivalent JSON config.
i need to to dynamically add domains in my site. Example, i have domain contests.com, i want the content of contests.com/contest/example to be shown when navigating from another domain examplecontest.com
Yes, you need to use a rewrite to change the path, and the proxy to send the request to another server.
