How to specify both issuer and acme dns at the same time?
2.4.6
with docker as always :slight_smile:
docker linux
    email myemail@address.tld
    acme_dns cloudflare APIKEY
    cert_issuer zerossl APIKEY
https://example.tld {
 reverse_proxy 127.0.0.1:8080
tls myemail@address.tld {
i get an error saying that i can’t put issuer like that but don’t really understand why, i would like to specify the apikey for zerossl so i can see on my dashboard information about the certs issued but didn’t manage to for this specify entry.
haven’t been able to reproduce the error
changing the syntax
If you specify it in global options, you don’t need to also specify it in each site. Just pick one.
But if you choose configuring via the site, then you need to put the dns config inside of the issuer. Like this:
	issuer zerossl APIKEY {
i’m using multiple dns zone i have to use multiple apikey.
with a configuration that looks like that :
i get this error :
{"level":"info","ts":????????.????????,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
run: adapting config using caddyfile: parsing caddyfile tokens for 'tls': /etc/caddy/Caddyfile:21 - Error during parsing: cannot mix issuer subdirective (explicit issuers) with other issuer-specific subdirectives (implicit issuers)
so if i understand i can’t use mutliples zerossl apikey ?
That seems like it’s only a subset of your config. What your entire config? How can I replicate this?
https://abc.example.tld {
   issuer zerossl APIKEY1{
    dns cloudflare APIKEY1
https://cde.example.tld {
 reverse_proxy 127.0.0.1:8181
https://efg.example.tld {
 reverse_proxy 127.0.0.1:8282
https://ghi.example.tld {
 reverse_proxy 127.0.0.1:9090
   issuer zerossl APIKEY2 {
    dns cloudflare APIKEY2
https://ijk.example.tld {
 reverse_proxy 127.0.0.1:10010
   issuer zerossl APIKEY3 {
    dns cloudflare APIKEY3
this should be more revelant about the config i use, i used single option only since i removed the general option to ensure that nothing interfere with the rest of the config.
i use 3 different dns zone with 3 differents zerossl apikey
Just making sure, you have a space between the API key and {, right? Whitespace is important, otherwise the { would be read as part of the API key.
All of those sites have the domain. That’s not a valid config.
oups sorry i forgot to update the domains
i’m gonna check that the typo is actually just me exporting my config in a bad way or if it was like that in my config
Oh, right. I forgot, the email when used as an argument to tls is technically an “issuer-specific subdirective” for implementation reasons. So the fix is to write it like this:
yes it seems it’s the solution.
thank you !
