Hello.
I ran the docker-compose -f prodution.yml up -build
command several times, after which I had to delete the files of my containers, and now when I try to repeat this, I get an error:
www.domain.com] failed to get certificate: acme: Error 429 - urn:acme:error:rateLimited - Error creating new cert :: too many certificates already issued for exact set of domains: domain: see https://letsencrypt.org/docs/rate-limits/
I understand that this is due to limits from LetsEncrypt, but how to solve this problem?
I do not have time to wait, I need to deploy my web application.
I think of two ways to solve this problem:
- Disable HTTPS, while there is no time to retrieve the certificate from LetsEncrypt
- Buy a premium certificate.
I tried the first method, but the web application was not available:
www.{$DOMAIN_NAME} {
redir https://domain.com
{$DOMAIN_NAME} {
proxy / myapp:5000 {
header_upstream Host {host}
tls
log stdout
errors stdout
gzip
Do you have any ideas on how I can get out of this situation as quickly as possible?
Thank you in advance.
