How to silence TLS handshake errors?
~ # ./caddy version
v2.0.0-rc.3 h1:z2H/QnaRscip6aZJxwTbghu3zhC88Vo8l/K57WUce4Q=
I am getting a lot of http: TLS handshake errors. Some of them are understandable, some less, some others will get fixed when I transition to the final configuration (replacing Traefik):
2020/04/26 17:45:07 http: TLS handshake error from 172.18.0.18:39426: local error: tls: bad record MAC
2020/04/26 17:45:07 http: TLS handshake error from 172.18.0.18:39430: local error: tls: bad record MAC
2020/04/26 17:45:07 http: TLS handshake error from 172.18.0.18:39436: local error: tls: bad record MAC
2020/04/26 17:45:07 http: TLS handshake error from 192.168.10.72:52126: remote error: tls: unknown certificate
2020/04/26 17:45:07 http: TLS handshake error from 172.18.0.18:39440: local error: tls: bad record MAC
2020/04/26 17:45:07 http: TLS handshake error from 172.18.0.27:58626: no certificate available for 'elasticsearch.XXX.info'
2020/04/26 17:45:07 http: TLS handshake error from 172.18.0.18:39448: local error: tls: bad record MAC
2020/04/26 17:45:07 http: TLS handshake error from 172.18.0.18:39452: local error: tls: bad record MAC
2020/04/26 17:45:07 http: TLS handshake error from 172.18.0.18:39454: local error: tls: bad record MAC
2020/04/26 17:45:08 http: TLS handshake error from 192.168.10.72:52127: remote error: tls: unknown certificate
2020/04/26 17:45:09 http: TLS handshake error from 172.18.0.17:51918: local error: tls: bad record MAC
2020/04/26 17:45:12 http: TLS handshake error from 192.168.10.72:52128: EOF
While I am debugging, is there a way to silence these errors?
These are emitted from the Go standard library and we have no control over them, except to discard all std lib logs (you can do this with Caddy, but I strongly advise against it).
Can’t you just ignore logs you’re not interested in?
Well in that case I will have to :slight_smile:
The problem down the road is that I will get plenty of such errors because anything.my.domain will get redirected to caddy , including all the chatter from Google Chrome (which uses random names to check the network):
2020/04/26 17:54:41 http: TLS handshake error from 192.168.10.143:61727: no certificate available for 'wwbbzlqlyhh'
Anyway, if there is nothing to do I will ignore them. Thanks a lot for the help!
The answer is probably that you can’t but it would be nice if all the messages were json rather than some json and some text. When I run the logs through json tools like jq it fails so I need to grep them out beforehand.
That seems like an oversight on jq’s part: How to skip non-json lines? · Issue #884 · stedolan/jq · GitHub
If someone figures out how to coerce all logs that we don’t control to be emitted as JSON (without high costs), I would be happy to see it.
Maybe use grep before piping to jq to skip lines that don’t start with {
tail -f logs | grep '^{' | jq '.'
That command is incomplete but you get the idea
