How to set up logging in caddyfile
I have set up caddy reverse proxy for my jellyfin server and after opening port 443 in my router and setting up the config file I can reach jellyfin from outside of my network. What I want to do is have some sort of logging file configured in the caddyfile so I can see if something fishy is going on.
nothing to see here..
╭─pi@raspberrypi /home/pi ‹system›
╰─$ caddy version
2.6.2
I installed it using apt (raspberrypios trixie) and run it with systemd
raspberry pi 4b running raspberrypios trixie
systemd service
larijani.ddns.net {
        reverse_proxy localhost:8096
In this case it should be
larijani.ddns.net {
    output file /var/log/caddy/jellyfin-access.log {
        roll_size 10MiB
        roll_keep 10
        roll_keep_for 720h
    format json
For example you should get log from that path or your own path
sudo mkdir -p /var/log/caddy
sudo chown caddy:caddy /var/log/caddy
sudo systemctl reload caddy
Hope i help
And you need update your caddy to 2.11.2
