hzb
(Bin Hua)
September 24, 2021, 12:00am
1
v2.4.5
I want to set a subpath like in Nginx
in Nginx
server {
listen 443;
server_name caddys.com;
ssl on;
root /root/blog;
//ssl configuration
location /books/ {
root /root/books;
index index.htm index.html;
How can I do the following part in Caddyfile?
location /books/ {
root /root/books;
Thank you so much.
hzb
(Bin Hua)
September 24, 2021, 12:24am
2
I checked help docs, I should use proxy.
Sorry to trouble.
You can use the handle_path
directive for this:
example.com {
handle_path /books* {
root * /root/books
root * /root/blog
Next time, please completely fill out the help topic template. Don’t delete any sections. It’s important to save time, and to avoid making us make assumptions about your setup.
hzb
(Bin Hua)
September 24, 2021, 9:50am
4
I see, thank you so much.
system
(system)
Closed
October 24, 2021, 12:01am
5
