v2.1.1
Ubuntu 20.04
systemctl start caddy
After=network.target
ReadWritePaths=/customPath/caddy
email admin@example.com
subdomain.example.com {
root * /var/www/subdomain
output file /var/log/subdomain.log
Strict-Transport-Security "max-age=15552000;"
X-Frame-Options "SAMEORIGIN" always
X-Permitted-Cross-Domain-Policies "none" always
X-Robots-Tag "none" always
X-XSS-Protection "1; mode=block" always
redir /.well-known/webfinger /public.php?service=webfinger
redir /.well-known/host-meta /public.php?service=host-meta
redir /.well-known/host-meta\.json /public.php?service=host-meta-json
@forbidden {
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
respond @forbidden 404
The HomeDir for caddy is wrong
$ caddy environ
caddy.HomeDir=/home/twinkybot
caddy.AppDataDir=/home/twinkybot/.local/share/caddy
caddy.AppConfigDir=/home/twinkybot/.config/caddy
caddy.ConfigAutosavePath=/home/twinkybot/.config/caddy/autosave.json
I want it to be /caddy, which I managed with
ReadWritePaths=/customPath/caddy in my service file.
But I want this to be in the Caddyfile. What do I need to configure?
Thanks.
