Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
I’m using the json version for the configuration file and just want to know how can I set a header field to a specific value ONCE for EVERY route I have defined under routes
The reason I haven’t added more is that I’m struggling to know where I should even start. I just find the documentation for the json format very non-intuitive and usually only make progress when I find some related example somewhere which then allows me to actually understand the docs. It’s most likely just the way my brain is wired.
I really like working with Caddy and now use it for pretty much any Go project with an http component, but I have also spent hours crawling the web to make sense on the configuration settings.
Please close the issue if you think if this is below the standard of what’s expected of an issue. It’s not a showstopper for me as there is a brute force work around.
