I would like to know how to serve pre-compressed files with Caddy v2. Example: when the browser requests the resource /js/app.js and header accept-encoding: gzip, if the resource exists with an extension gz, like /js/app.js.gz, so the response should use the compressed file with the appropriate response header set (content-encoding: gzip).
Right now, the situation is not ideal for this in Caddy, but we do have plans to improve this eventually.
https://github.com/caddyserver/caddy/issues/2665
For now though, the approach to take would be to use a file matcher to see if {path}.gz exists on disk, and if so, handle the request with a handle block that rewrites the request, sets the Content-Type and Content-Encoding. You’ll need to do one of these matcher/handler blocks per file type you want to support because Caddy only looks at the file extension to know the file type and it will only see .gz when determining the content type header to send.
I’m on my phone right now so I can’t type out a full example, but I hope that gets you on the right track.
Thanks. I would appreciate to see the full example.
It would probably look something like this:
@gzippedJS {
header Accept-Encoding *gzip*
path *.js
file {
try_files {path}.gz
handle @gzippedJS {
header Content-Encoding gzip
header Content-Type text/javascript
rewrite {path}.gz
You’d have a block like this for each type of file type you have precompressed.
This is the actual Caddyfile, that works partially:
:8383
root * /usr/share/caddy
@gzip {
file {
try_files {path}.gz
handle /js/* {
handle @gzip {
header Alex compressed
rewrite {path}.gz
# Support for SPA.
try_files {path} /index.html
The path /js/vendor.js is served from the /js/vendor.js.gz if the browser requests gzip encoding. But the response contains the unknown header Alex: compressed. If I change to the correct header Content-Encoding: gzip, the solution does not work!
In summary, this will NOT work:
handle /js/* {
handle @gzip {
rewrite {path}.gz
What’s missing?
What doesn’t work? Just saying “this will NOT work” doesn’t tell us anything. Please elaborate.
The following Caddyfile is working correctly:
:8383
@gzip {
file {
try_files {path}.gz
handle /js/* {
handle @gzip {
rewrite {path}.gz
# Support for SPA.
This is the curl I have used for testing it:
curl -H "Accept-Encoding: gzip" -D - http://localhost:8383/js/vendor.js
Caddy correctly served the file /js/vendor.js.gz, and all the response headers are also correct:
Accept-Ranges: bytes
Content-Type: text/javascript
Etag: "qcbnly3ojc"
Last-Modified: Mon, 22 Jun 2020 09:56:22 GMT
Server: Caddy
Date: Mon, 22 Jun 2020 13:59:13 GMT
Transfer-Encoding: chunked
FYI you can simplify that Caddyfile to this, and it should work just the same:
:8383
@gzipJS {
file {
try_files {path}.gz
path /js/*
handle @gzipJS {
rewrite {path}.gz
# Support for SPA.
