How to Serve Laravel Application in handle or handle_path directives
I have multiple apps and I only have 1 DNS. To separate the apps, I add prefix in the URI, e.g. www.domain.test/app-1, www.domain.test/app-2, and so on. So I preferred to use handle or handle_path directives in my configurations. The Problem: Only my laravel application always ends-up to 404 Not Found.
![image|690x325](upload://9cYbm5HQ7ehqr8LD9KW2CREbs96.png)
v2.7.4
OS: Ubuntu 22.04.3 LTS 22.04 Jammy
Laravel: v9
b. My complete Caddy config:
sub.domain.test {
   encode zstd gzip
   import static
   import security
   handle_path /alias-laravel-app* {
     root * /var/www/html/laravel-app/public
     php_fastcgi unix//var/run/php/php8.1-fpm.sock
   php_fastcgi unix//var/run/php/php7.4-fpm.sock
You’ll need to configure your routes (in web.php probably) to be aware of /alias-laravel-app as a base. You can wrap all your routes like this:
Route::prefix('alias-laravel-app')->group(function () {
    // Your routes here
See this article:
Ultimately the key is that your upstream app needs to be aware of being run within a subpath.
It worked, Thanks for the idea.
