I’m trying to serve some static files from this EteSync Docker image. I’ve got all the Docker stuff working, so no need to worry about that. What I’m now trying to do is convert this nginx config to a Caddyfile config.
upstream etebase {
server etebase:3735; # for a web port socket (we'll use this first)
# https://ssl-config.mozilla.org/#server=nginx&version=1.18.0&config=intermediate&openssl=1.1.1d&ocsp=false&guideline=5.6
server {
listen 80 default_server;
listen [::]:80 default_server;
charset utf-8;
# max upload size
client_max_body_size 75M; # adjust to taste
location /static/ {
autoindex on;
alias /srv/etebase/static/; # Project's static files
location /user-media/ {
autoindex on;
alias /srv/etebase/media/;
location / {
proxy_pass http://etebase;
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $server_name;
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /usr/share/nginx/html;
I was thinking it would just be something like this, because the static files are in /srv/etebase/static
sync.example.com { # EteSync
route {
file_server * browse {
root /srv/etebase/static
reverse_proxy localhost:3735
This does server the static files, but there’s a lot of other complicated looking stuff in the nginx config, and I’m not sure if I’ve converted it all over.
My Caddy version is 2.4.6, by the way.
Thanks!
