I’m using path_regexp:
uri path_regexp ^/index/([^/]+)/([^/]+)$ /index.php?codigo=$1&cidade=$2
Using the Debug, I see it don’t works because it doesn’t keep the question sign (?) after the name page. The debug shows me that the generated uri is:
/index.php%3Fcodigo=565657&cidade=Franca
See above that it puts “%3F” at question sign place. I already tried two slashes (\\) before question sign, but it doesn’t work too. I need the result of my regex be:
/index.php?codigo=565657&cidade=Franca
How do I do it?
It goes to index.html page, because it doesn’t find the wrong path generated by regex above
binary file
Debian Linux 11.0
caddy run --config Caddyfile
The URL I’m calling:
127.0.0.1:9191/index/565657/Franca
:9191 {
root * /home/paulo/projeto_php
php_fastcgi 127.0.0.1:9001
try_files {path} index.html index.htm
