neezer
(Evan Sherwood)
November 10, 2022, 7:20pm
1
1. Output of caddy version
macOS Ventura 13.0
N/A
http://localhost:8773
@age {
file
path_regexp \.age$
rewrite @age /entry.html
root * ./srv
file_server {
pass_thru
file_server {
root ./entries
browse
templates
I want to only rewrite a request to
a file that exists
a file that ends in a specific extension
… otherwise I want to 404.
With the Caddyfile above, the file resolves (prints out the file contents) instead of being rewritten to /entry.html
None.
I can get the rewrite working with just
@age `{path}.endsWith("age")`
… but that does not 404 if the file doesn’t exist.
I’ve also tried handling the 404 logic in entry.html
(since it’s a template), using something like this:
{{if not (fileExists .OriginalReq.URL.Path)}}{{httpError 404}}{{end}}
<!-- rest of entry.html -->
… but fileExists
seems to always return false
even when I know my path is correct, so this always 404s.
None that I know of.
I’m not sure why the regexp doesn’t work. It should, I think.
But either way, you can do this, I think:
@age `file() && {path}.endsWith(".age")`
neezer
(Evan Sherwood)
November 10, 2022, 8:47pm
3
That gives me this error… ?
expression: compiling CEL program: ERROR: <input>:1:5: matcher requires at least one argument
| file() && caddyPlaceholder(request, "http.request.uri.path").endsWith(".age")
Ah - I guess we didn’t implement an overload for no params. Maybe file({})
will work.
If not, do file("{path}")
I think. Although that might also not work for other reasons.
neezer
(Evan Sherwood)
November 10, 2022, 9:02pm
5
The former resolves the file (prints file contents) and doesn’t perform the rewrite.
The latter yields this error:
expression: compiling CEL program: ERROR: <input>:1:34: Syntax error: mismatched input 'http' expecting ')'
| file("caddyPlaceholder(request, "http.request.uri.path")") && caddyPlaceholder(request, "http.request.uri.path").endsWith(".age")
ERROR: <input>:1:55: Syntax error: mismatched input '")"' expecting <EOF>
I’m guessing because of the quotes.
Yeah. The expression parsing logic is… funky.
I think file({path})
should work, actually. Our tests cover that one.
neezer
(Evan Sherwood)
November 10, 2022, 9:27pm
7
@age `file({path}) && {path}.endsWith(".age")`
… resolves the file (no rewrite).
matt
(Matt Holt)
November 10, 2022, 9:28pm
8
Just curious as to the usecase, are you perchance serving age-encrypted-at-rest files from disk over TLS and then the client is decrypting them? Or decrypting them on-the-fly for clients?
Either way, I could see some interesting plugin functionality here
neezer
(Evan Sherwood)
November 10, 2022, 9:35pm
9
@matt Yup. I’m serving age-encrypted-at-rest files to the client. Decryption & re-encryption happens in the client application only (not on-the-fly).
@francislavoie I manage to get this working by moving the top-level root
directive inside the first file_server
directive, so now I have this:
@age `{path}.endsWith(".age")`
file_server {
root ./srv
pass_thru
file_server {
root ./entries
browse
That makes my fileExists
detection work inside my template:
{{$filepath := printf "/entries%s" .OriginalReq.URL.Path}}
{{if not (fileExists $filepath)}}{{httpError 404}}{{end}}
It feels a bit weird to have to rely on the template for the 404 handling, though–I’d love to find a solution that captures this logic cleanly & directly in the Caddyfile.
matt
(Matt Holt)
November 11, 2022, 3:57am
10
Does this work?
@age {
file
path *.age
The regular path matcher can match a suffix easily enough. I would think that should work. ^ I really don’t think CEL or regexp are required… if so, I’m interested in looking into this more because I don’t think that should be the case, with my current understanding.
Anyway, once that works, then I want to come back to the 404’ing because I bet it can probably be done in the Caddyfile too.
The file
matcher uses your root
that you defined. If you don’t use root
then it will look for files in Caddy’s working directory (that depends on how you ran Caddy).
neezer
(Evan Sherwood)
November 11, 2022, 4:29am
12
@matt Nope, that doesn’t work. It returns the file contents instead of performing the rewrite.
matt
(Matt Holt)
November 11, 2022, 5:16am
13
I’m not able to reproduce that behavior.
With a file called hello.txt
in a new directory, this config:
localhost
@age {
file
path *.txt
respond @age "Oh it's txt!"
respond "Not txt"
works for me:
$ curl -v "https://localhost/hello.txt"
* Trying 127.0.0.1:443...
* Connected to localhost (127.0.0.1) port 443 (#0)
* CApath: none
* ALPN: offers http/1.1
* ALPN: server accepted http/1.1
* SSL connection using TLSv1.3 / TLS13-AES128-GCM-SHA256
> GET /hello.txt HTTP/1.1
> Host: localhost
> User-Agent: curl/7.86.0-DEV
< HTTP/1.1 200 OK
< Alt-Svc: h3=":443"; ma=2592000
< Server: Caddy
< Date: Fri, 11 Nov 2022 05:15:13 GMT
< Content-Length: 12
Oh it's txt!
$ curl -v "https://localhost/test.txt"
* CApath: none
> GET /test.txt HTTP/1.1
> Host: localhost
< HTTP/1.1 200 OK
< Server: Caddy
< Date: Fri, 11 Nov 2022 05:15:16 GMT
< Content-Length: 7
Not txt
Can you please verify by posting directory contents and curl output?
neezer
(Evan Sherwood)
November 11, 2022, 5:26am
14
@matt Using your proposed change:
Directory contents:
├── Caddyfile
├── entries
│ └── a
│ └── b
│ └── test.tar.gz.b64.age
└── srv
└── entry.html
Caddyfile:
@age {
file
path *.age
file_server {
root ./srv
pass_thru
file_server {
root ./entries
browse
templates
Curl output from curl -v http://localhost:8773/a/b/test.tar.gz.b64.age
* Trying 127.0.0.1:8773...
* Connected to localhost (127.0.0.1) port 8773 (#0)
> GET /a/b/test.tar.gz.b64.age HTTP/1.1
> Host: localhost:8773
> User-Agent: curl/7.84.0
< HTTP/1.1 200 OK
< Accept-Ranges: bytes
< Content-Length: 580
< Etag: "rl5je6g4"
< Last-Modified: Thu, 10 Nov 2022 21:51:42 GMT
< Server: Caddy
< Date: Fri, 11 Nov 2022 05:19:05 GMT
-----BEGIN AGE ENCRYPTED FILE-----
YWdlLWVuY3J5cHRpb24ub3JnL3YxCi0+IFgyNTUxOSBKb3lETUI4M0hCZ3ZvN1dW
alhLOWFHQ2lwMGI4TjVKd3RIaUhrOFBrRjFnCmNhUVJrSE9aVnlJUVdUMXhNUXFO
SjQydTg1aHlHOVF3OWl5V0xjOEcwNEkKLS0tIFFtd2crSVVWUGZqZDh5NzlyamdR
QXZhT3FiZGd2a1lrV2d5VHI5RFBFdHcKeguNwom6rdk94Xw+T2dz8KFW3bjLZteX
Cxc+0aX57NNOm8GcEYe502aIpkD3KV8oagnZPgs0CO9ntA3uBpqA+ToTH0d6OFQd
YxTkDHGsbjFpeNPyV5nxIzJoeysWCTr5IHeOudfkD4p+8QrcjLetPkukvf2zlMze
MSRwRhoDg956flVTiqH/nBcxAnmr5c98KSnybye9olAdg7knitftmvw1jMF6kF8+
UL1whiDPEtFoCn/7MfDDqXZX9kzaBoSikLsBeaXLRDgNUDJlj/qYCMY=
-----END AGE ENCRYPTED FILE-----
This is not desired behavior. What I want is the content from /entry.html
, which should look like this:
< HTTP/1.1 200 OK
< Content-Length: 2245
< Content-Type: text/html; charset=utf-8
< Server: Caddy
< Date: Fri, 11 Nov 2022 05:22:59 GMT
<!DOCTYPE html>
<html>
<head>
<!-- ... truncated ... -->
<script>
globalThis.entryEnc = `-----BEGIN AGE ENCRYPTED FILE-----
</script>
</head>
<body>
</body>
</html>
The file contents of a/b/test.tar.gz.b64.age
are injected into the HTML since entry.html
is a template.
Does that clarify?
matt
(Matt Holt)
November 11, 2022, 4:00pm
15
I think I see what you’re saying, but I’m still able to get what I think is the desired behavior with this Caddyfile:
localhost
@age {
file
path *.txt
templates
file_server {
pass_thru
file_server browse
Requesting hello.txt
(which exists) serve entry.html
. Requesting /
serves a file listing (browse). Requesting noexist.txt
serves a 404.
neezer
(Evan Sherwood)
November 11, 2022, 4:45pm
16
Where on your file system is entry.html
located in your example? Your file_server
directives don’t specify different roots: mine do. Would that make a difference?
neezer
(Evan Sherwood)
November 11, 2022, 4:52pm
17
Ahh! That was actually it. Modifying your example to this works:
@age {
file {
root ./entries
path *.age
… which makes sense, since it was looking in wrong root for the .age file and thus couldn’t find it on the file system, so the matcher missed.
matt
(Matt Holt)
November 11, 2022, 5:06pm
18
Yeah, it was just in the same dir (current working folder).
So, in summary, you shouldn’t need regex or CEL. Standard matcher/directive pattern should do it just fine.
Thanks for following up!
system
(system)
Closed
December 10, 2022, 7:20pm
19
