How to reverse_proxy and allow cors in v2
1. My Caddy version (caddy -version)
I am using caddy/caddy:alpine in docker. Don’t know what version of 2 that is.
Digitalocean market place droplet Ubuntu Docker 5:19.03.1~3 on 18.04
version: '3.7'
  db:
    # specify container name to make it easier to run commands.
    # for example, you could run docker exec -i postgres psql -U postgres postgres < schema.sql to run an SQL file against the Postgres database
    container_name: ae_db
    restart: always
    image: db
    build:
      context: ./db
    env_file:
      - ./.env
      - network
    expose:
      - '5432'
      # make the Postgres database accessible from outside the Docker container on port 5432
      - '5432:5432'
      - db_data:/var/lib/postgresql/data
      - sik_data:/sik_data
  graphql:
    container_name: ae_graphql
    build:
      context: ./graphql
      - network
    expose:
      - '5000'
      - '5000:5000'
    depends_on:
      - db
    env_file:
      - ./.env
    command:
        '--connection',
        '${DATABASE_URL}',
        '--schema',
        'ae',
        '--append-plugins',
        'postgraphile-plugin-connection-filter,@graphile-contrib/pg-order-by-related',
        '--jwt-token-identifier',
        'auth.jwt_token',
        '--default-role',
        'anon',
        '--jwt-secret',
        '${JWT_SECRET}',
        '--cors',
        '--disable-query-log',
        '--enable-query-batching',
        '--retry-on-init-fail',
  json:
    container_name: ae_json
    restart: always
    build:
      context: ./json
      - network
    expose:
      - '4000'
      - '4000:4000'
    depends_on:
      - db
    env_file:
      - ./.env
    build:
      context: ./caddy
    container_name: ae_caddy
      - network
    depends_on:
      - graphql
      - json
    restart: always
    # image downgrades user but that seems not to work, see: https://caddy.community/t/basic-docker-compose-setup-failing/6892/7?u=alexander_gabriel
    user: root
      - '80:80'
      - '443:443'
    env_file:
      - ./.env
      - caddy_certs:/root/.local/share/caddy
      - caddy_config:/root/.config/caddy
  db_data:
  sik_data:
  caddy_certs:
  caddy_config:
  network:
d. My complete Caddyfile:
  email alex.barbalex@gmail.com
direktbegruenung.ch {
  # try proxying these - they should not be cross-domain
  reverse_proxy /graphql* localhost:5000
  reverse_proxy /graphiql* localhost:5000
  reverse_proxy /artendb/* localhost:4000
  reverse_proxy /evab* localhost:4000
  reverse_proxy /alt* localhost:4000
  root * /html
# original goal - but never worked
api.direktbegruenung.ch {
  reverse_proxy /graphql* {
    to localhost:5000
    header_down Access-Control-Allow-Origin *
  reverse_proxy /graphiql* {
    to localhost:5000
  reverse_proxy /evab* {
    to localhost:4000
    header_up Access-Control-Allow-Origin *
  reverse_proxy /alt* {
    to localhost:4000
# should work with:
# https.graphql.direktbegruenung.ch/graphql
# and
# https.graphql.direktbegruenung.ch/graphiql
graphql.direktbegruenung.ch {
  reverse_proxy * localhost:5000 {
# should work with:
# https.json.direktbegruenung.ch/alt
# and
# https.json.direktbegruenung.ch/evab
json.direktbegruenung.ch {
  reverse_proxy * localhost:4000 {
I have mixed header_up and header_down just so I have tried any possible combination.
The entire project is here: ae2/backend at master · FNSKtZH/ae2 · GitHub
I have an app consisting of
  • frontend (react-app)
  • db: PostgreSQL listening on port 5432 which should also be reachable from outside (using PgAdmin)
  • graphql-api: Postgraphile listening on port 5000
  • json-api: hapi server listening on port 4000 (probably caddy could be used instead but this is for later)
The goal is to serve (I will refer to this as alternative 0):
  • frontend on base-url.ch
  • graphql-api on api.base-url.ch/graphql
  • graphiql on api.base-url.ch/graphiql
  • an api for an app called alt on api.base-url.ch/alt
  • an api for an app called evab on api.base-url.ch/evab
Because this has been hard to achieve I have also tried two alternatives:
Alternative 1:
  • graphql-api on graphql.base-url.ch/graphql
  • graphiql on graphql.base-url.ch/graphiql
  • an api for an app called alt on json.base-url.ch/alt
  • an api for an app called evab on json.base-url.ch/evab
Alternative 2:
  • graphql-api on base-url.ch/graphql
  • graphiql on base-url.ch/graphiql
  • an api for an app called alt on base-url.ch/alt
  • an api for an app called evab on base-url.ch/evab
Alternative 1 separates subdomains by service which might make routing simpler.
Alternative 2 should hopefully eliminate cross origin requests as api and app are on the exact same domain.
Unfortunately I have gotten none of these alternatives to work correctly. I have read the documentation repeatedly and searched the internet for examples. But I am pretty sure that I have misunderstood how this is supposed to be done because I simply do not know how it is meant to be done. Also I am a frontend guy, not versed in this backend code. But the problem should be rather common, I should think.
Building caddy results in this log:
root@artdaten:~/ae# docker logs ae_caddy
2020/02/05 10:45:15.563 INFO    using provided configuration    {"config_file": "/etc/caddy/Caddyfile", "config_adapter": "caddyfile"}
2020/02/05 10:45:15.620 INFO    admin   admin endpoint started  {"address": "localhost:2019", "enforce_origin": false, "origins": ["localhost:2019"]}
2020/02/05 10:45:15.620 INFO    http    server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2020/02/05 10:45:15.620 INFO    http    enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2020/02/05 10:45:15.621 INFO    http    enabling automatic TLS certificate management   {"domains": ["direktbegruenung.ch", "graphql.direktbegruenung.ch", "json.direktbegruenung.ch", "api.direktbegruenung.ch"]}
2020/02/05 10:45:15.633 INFO    tls     cleaned up storage units
2020/02/05 10:45:15.633 INFO    autosaved config        {"file": "/root/.config/caddy/autosave.json"}
2020/02/05 10:45:15.633 INFO    serving initial configuration
2020/02/05 10:45:15 [INFO][cache:0xc00009c0a0] Started certificate maintenance routine
…so that seems to work o.k.?
Here are the issues, grouped by alternative solutions:
Alternative 0:
curl https://api.direktbegruenung.ch/graphql returns nothing. This appears in the log:
root@artdaten:~/ae# docker logs ae_caddy --since 2m
2020/02/05 10:32:29.188 ERROR   http.log.error  dial tcp 127.0.0.1:5000: connect: connection refused    {"request": {"method": "GET", "uri": "/graphql", "proto": "HTTP/2.0", "remote_addr": "167.172.187.231:50708", "host": "direktbegruenung.ch", "headers": {"User-Agent": ["curl/7.58.0"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 772, "ciphersuite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "direktbegruenung.ch"}}, "status": 502, "err_id": "6naxtqce4", "err_trace": "reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:362)"}
2020/02/05 10:33:33 [INFO][cache:0xc00022f360] Scanning for stale OCSP staples
2020/02/05 10:33:33 [INFO][cache:0xc00022f360] Done checking OCSP staples
curl -v https://api.direktbegruenung.ch/graphql returns:
root@artdaten:~/ae# curl -v https://api.direktbegruenung.ch/graphql
*   Trying 167.172.187.231...
* TCP_NODELAY set
* Connected to api.direktbegruenung.ch (167.172.187.231) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.3 (IN), TLS Unknown, Certificate Status (22):
* TLSv1.3 (IN), TLS handshake, Unknown (8):
* TLSv1.3 (OUT), TLS change cipher, Client hello (1):
* TLSv1.3 (OUT), TLS Unknown, Certificate Status (22):
*  subject: CN=api.direktbegruenung.ch
*  start date: Feb  4 22:14:58 2020 GMT
*  expire date: May  4 22:14:58 2020 GMT
*  subjectAltName: host "api.direktbegruenung.ch" matched cert's "api.direktbegruenung.ch"
*  issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
* TLSv1.3 (OUT), TLS Unknown, Unknown (23):
* Using Stream ID: 1 (easy handle 0x558b7e342580)
> GET /graphql HTTP/2
> Host: api.direktbegruenung.ch
> User-Agent: curl/7.58.0
* TLSv1.3 (IN), TLS Unknown, Unknown (23):
* Connection state changed (MAX_CONCURRENT_STREAMS updated)!
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Wed, 05 Feb 2020 10:23:49 GMT
* Connection #0 to host api.direktbegruenung.ch left intact
Using https://api.direktbegruenung.ch/graphql from the frontend results in this logged in the console:
Access to fetch at 'https://api.direktbegruenung.ch/graphql' from origin 'https://direktbegruenung.ch' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
Alternative 1:
curl https://graphql.direktbegruenung.ch/graphql returns nothing.
This appears in the logs:
2020/02/05 10:34:55.260 ERROR   http.log.error  dial tcp 127.0.0.1:5000: connect: connection refused    {"request": {"method": "GET", "uri": "/graphql", "proto": "HTTP/2.0", "remote_addr": "167.172.187.231:50716", "host": "graphql.direktbegruenung.ch", "headers": {"User-Agent": ["curl/7.58.0"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 772, "ciphersuite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "graphql.direktbegruenung.ch"}}, "status": 502, "err_id": "a4cgjkmyu", "err_trace": "reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:362)"}
curl -v https://graphql.direktbegruenung.ch/graphql returns:
root@artdaten:~/ae# curl -v https://graphql.direktbegruenung.ch/graphql
* TCP_NODELAY set
* Connected to graphql.direktbegruenung.ch (167.172.187.231) port 443 (#0)
* ALPN, offering h2
*  subject: CN=graphql.direktbegruenung.ch
*  start date: Feb  4 22:14:57 2020 GMT
*  expire date: May  4 22:14:57 2020 GMT
*  subjectAltName: host "graphql.direktbegruenung.ch" matched cert's "graphql.direktbegruenung.ch"
* Using Stream ID: 1 (easy handle 0x5639e2007580)
> GET /graphql HTTP/2
> Host: graphql.direktbegruenung.ch
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Wed, 05 Feb 2020 10:30:16 GMT
* Connection #0 to host graphql.direktbegruenung.ch left intact
Using https://graphql.direktbegruenung.ch/graphql from the frontend results in this logged in the console:
Access to fetch at 'https://graphql.direktbegruenung.ch/graphql' from origin 'https://direktbegruenung.ch' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
Alternative 2:
curl https://direktbegruenung.ch/graphql returns nothing.
root@artdaten:~/ae# docker logs ae_caddy --since 1m
2020/02/05 10:35:50.733 ERROR   http.log.error  dial tcp 127.0.0.1:5000: connect: connection refused    {"request": {"method": "GET", "uri": "/graphql", "proto": "HTTP/2.0", "remote_addr": "167.172.187.231:50722", "host": "direktbegruenung.ch", "headers": {"User-Agent": ["curl/7.58.0"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 772, "ciphersuite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "direktbegruenung.ch"}}, "status": 502, "err_id": "j9eiqsmht", "err_trace": "reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:362)"}
curl -v https://direktbegruenung.ch/graphql returns:
root@artdaten:~/ae# curl -v https://direktbegruenung.ch/graphql
* TCP_NODELAY set
* Connected to direktbegruenung.ch (167.172.187.231) port 443 (#0)
* ALPN, offering h2
*  subject: CN=direktbegruenung.ch
*  start date: Feb  4 22:14:56 2020 GMT
*  expire date: May  4 22:14:56 2020 GMT
*  subjectAltName: host "direktbegruenung.ch" matched cert's "direktbegruenung.ch"
* Using Stream ID: 1 (easy handle 0x55c83dd1e580)
> GET /graphql HTTP/2
> Host: direktbegruenung.ch
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Wed, 05 Feb 2020 10:32:29 GMT
* Connection #0 to host direktbegruenung.ch left intact
Using https://direktbegruenung.ch/graphql from the frontend results in this logged in the console:
POST https://direktbegruenung.ch/graphql 502
Searched docs, issues and the internet. Tried many combinations of how I thought it maybe should be done.
Going over your error messages / full log output:
In all three alternatives, we see some variation of 2020/02/05 10:32:29.188 ERROR http.log.error dial tcp 127.0.0.1:5000: connect: connection refused
The listener at 127.0.0.1:5000 is rejecting your connection. Is Postgraphile actually running? If it is, is it actually running on port 5000? If yes, are there any settings that would cause it to refuse connections outright from localhost?
Now, the other problem we’re seeing:
However, we see you’re running header_down Access-Control-Allow-Origin * on… basically every proxy (except for json subdomain, which is header_up - you definitely do want header_down in order to get that header coming back to the client).
So, yeah, these are… strange. Can you issue a curl -IL graphql.direktbegruenung.ch and show what headers you actually get back? We need to see if we’re getting some malformed Access-Control-Allow-Origin header, or no header at all, or whatever else might be going on.
One option to try after checking that would be to use the header directive straight on the actual site itself, rather than adding header_down to all the proxies, e.g.: header Access-Control-Allow-Origin direktbegruenung.ch
I am now trying to dumb things down to an absolute minimum, even if it is not what is needed.
So I am now trying this minimal configuration:
  root * /html
Good things first: direktbegruenung.ch returns the app just as expected. So serving the files works.
The call to https://direktbegruenung.ch/graphql stil results in a 502. Here the log from docker logs ae_caddy:
2020/02/15 09:51:43.055	ERROR	http.log.error	dial tcp 127.0.0.1:5000: connect: connection refused	{"request": {"method": "POST", "uri": "/graphql", "proto": "HTTP/2.0", "remote_addr": "178.197.227.192:42690", "host": "direktbegruenung.ch", "headers": {"Origin": ["https://direktbegruenung.ch"], "Sec-Fetch-Site": ["same-origin"], "Sec-Fetch-Mode": ["cors"], "Sec-Fetch-Dest": ["empty"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36"], "Dnt": ["1"], "Referer": ["https://direktbegruenung.ch/"], "Accept-Encoding": ["gzip, deflate, br"], "Accept-Language": ["de-CH,de;q=0.9,en-US;q=0.8,en;q=0.7,es-CR;q=0.6,es;q=0.5,de-DE;q=0.4"], "Content-Length": ["6091"], "Accept": ["*/*"], "Content-Type": ["application/json"]}, "tls": {"resumed": false, "version": 772, "ciphersuite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "direktbegruenung.ch"}}, "status": 502, "err_id": "2zyu570g9", "err_trace": "reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:362)"}
I have no idea why the graphql endpoint would refuse the connection. This is the log from docker logs ae_graphql:
root@artdaten:~/ae# docker logs ae_graphql
PostGraphile v4.5.5 server listening on port 5000 🚀
  ‣ GraphQL API:         http://0.0.0.0:5000/graphql
  ‣ GraphiQL GUI/IDE:    http://0.0.0.0:5000/graphiql (enhance with '--enhance-graphiql')
  ‣ Postgres connection: postgres://postgres:[SECRET]@db/ae
  ‣ Postgres schema(s):  ae
  ‣ Documentation:       https://graphile.org/postgraphile/introduction/
  ‣ Join Frank in supporting PostGraphile development: https://graphile.org/sponsor/
It looks like no query ever reached the graphql endpoint because that should have been logged.
Above output is the exact same that PostGraphile returns when manually run on my PC/MacBook, using the exact same command. So I do not know what could have gone wrong.
The exact same problem occurs when calling https://direktbegruenung.ch/alt. docker logs ae_caddy shows:
2020/02/15 10:13:27.445	ERROR	http.log.error	dial tcp 127.0.0.1:4000: connect: connection refused	{"request": {"method": "GET", "uri": "/alt", "proto": "HTTP/2.0", "remote_addr": "178.197.227.192:47881", "host": "direktbegruenung.ch", "headers": {"Sec-Fetch-Site": ["same-origin"], "Accept-Encoding": ["gzip, deflate, br"], "Accept-Language": ["de-CH,de;q=0.9,en-US;q=0.8,en;q=0.7,es-CR;q=0.6,es;q=0.5,de-DE;q=0.4"], "Cache-Control": ["max-age=0"], "Sec-Fetch-Dest": ["empty"], "Upgrade-Insecure-Requests": ["1"], "Dnt": ["1"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36"], "Sec-Fetch-Mode": ["same-origin"]}, "tls": {"resumed": true, "version": 772, "ciphersuite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "direktbegruenung.ch"}}, "status": 502, "err_id": "1afpbt566", "err_trace": "reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:362)"}
and docker logs ae_json:
root@artdaten:~/ae# docker logs ae_json
JSON-API-Server running at: http://0.0.0.0:4000
Just as in the graphql endpoint: Nothing was logged. As if nothing ever had arrived here.
Oh, it’s because they’re in different containers. That wasn’t clear until your last post. localhost will only try to connect to services that are also within the same container as Caddy. If you’re using docker-compose, then you can proxy to ae_graphql:5000 for example, which will use the docker network DNS to route the request to your graphql container.
That solved ALL the issues :tada:
So basically everything was correct but for the fact that localhost:5000 had to be replaced with ae_graphql:5000 in the Caddyfile. Similarly localhost:4000 had to be replaced with ae_json:4000.
This makes complete sense in hindsight. Using new technologies for the first time tends to be quite an adventure…
@francislavoie please have a beer and enjoy having saved my ass! I can’t thank you enough.
I don’t drink beer, but cheers all the same! :joy:
