I can’t reverse proxy AdGuardHome DoH.
{"level":"error","ts":1690207331.5979323,"logger":"http.log.error","msg":"tls: failed to verify certificate: x509: certificate is valid for *.example.com, example.com, not adguardhome","request":{"remote_ip":"180.245.195.103","remote_port":"53727","proto":"HTTP/3.0","method":"POST","host":"dns-ads.example.com","uri":"/dns-query","headers":{"Accept-Encoding":["identity"],"Content-Type":["application/dns-message"],"Accept":["application/dns-message"],"Accept-Language":["*"],"User-Agent":["Chrome"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h3","server_name":"dns-ads.example.com"}},"duration":0.003965345,"status":502,"err_id":"t3tq4atj9","err_trace":"reverseproxy.statusError (reverseproxy.go:1299)"}
Docker running on Debian 11
proxy:
image: caddy:2
container_name: proxy
- "443:443/tcp"
- "443:443/udp"
- ./caddy/Caddyfile:/etc/caddy/Caddyfile:ro
- ./caddy/site:/srv
- ./caddy/data:/data
- ./caddy/config:/config
- ./certbot/cert:/etc/letsencrypt:ro
- TZ=Asia/Jakarta
proxy:
ipv4_address: 10.1.1.254
# TLS Security
(tls) {
tls /etc/letsencrypt/live/example.com/fullchain.pem /etc/letsencrypt/live/example.com/privkey.pem {
protocols tls1.2 tls1.3
ciphers TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
dns-ads.example.com {
route /dns-query/*
uri strip_prefix /dns-query
reverse_proxy https://adguardhome:443 {
header_up Host {host}
import tls
