How to reuse code in Caddyfiles?
For example, I currently have a massive list of:
one.example.com {
    proxy / https://one.example.com:9000 {
    log /var/log/caddy/access.one.example.com.log
    errors /var/log/caddy/error.one.example.com.log
two.example.com {
    proxy / https://two.example.com:9000 {
    log /var/log/caddy/access.two.example.com.log
    errors /var/log/caddy/error.two.example.com.log
three.example.com {
    proxy / https://three.example.com:9000 {
    log /var/log/caddy/access.three.example.com.log
    errors /var/log/caddy/error.three.example.com.log
I couldn’t see how snippets could work for me here. If they could, I think the docs could cement with clearer examples.
I want to describe my caddyfile something like this:
  • modules/template1
  • Caddyfile
modules/template1:
{$domain} {
    proxy / https://{$domain}:9000 {
    log /var/log/caddy/access.{$domain}.log
    errors /var/log/caddy/error.{$domain}.log
Caddyfile:
from modules import template1
template1 {
    domain one.example.com
template1 {
    domain two.example.com
template1 {
    domain three.example.com
I hope the above conveys the point. Is there a way to define a function with input variables?
Hi @dnk8n, the Caddyfile doesn’t have any syntax like this. Snippets are the closest thing.
You might want to look at using some templating tools to generate your Caddyfile.
Caddy 2 may also be of interest here, since its configuration is designed to be programmable.
I think this request would solve part of your issue, if the Endian problem were addressed…
@matt, any chance of this making it into caddy?
Caddy 2 adopts that endianness. (0 == right-most label)
The direction of the label placeholders isn’t a concern in this case.
It’s possible to get the domain name from the {hostname} placeholder.
However, the proxy target can’t be dynamic, and the Caddyfile doesn’t “template” itself out in a way such as to allow this kind of repetition with minor changes. All individual proxies with distinct upstreams would have to be enumerated.
