caddy 2.2.1
Systemctl start caddy
ubuntu 20.04
Paste command here.
:2020 {
@options {
method OPTIONS
respond @options 204
header Access-Control-Allow-Origin *
header Access-Control-Allow-Credentials true
header Access-Control-Allow-Headers Auth-Token,Content-Type,Access-Token
header Access-Control-Allow-Methods OPTIONS,GET,POST
reverse_proxy http://127.0.0.1:3030
encode zstd gzip
I want use header Access-Control-Allow-Origin * to allow CROS, but GOT 405 ERROR in my browser.
This is the detailed message of the error:
A cross-origin resource sharing (CORS) request was blocked because the response to the associated preflight request had an unsuccessful HTTP status code and/or was a redirect.
To fix this issue, ensure all CORS preflight `OPTION` requests are answered with a successful HTTP status code (2xx) and do not redirect.
When use nginx, this can be done by add this code :
if ($request_method = 'OPTIONS') {
return 204;
So, I want to know if caddy can support this?
