2.0.0
AWS EC2 T2 Micro, Amazon Linux 2, Docker 19.03
docker build -t caddy .
docker run --name caddyserver -v $PWD/Caddyfile:/etc/caddy/Caddyfile -v $PWD/caddy.json:/etc/caddy/caddy.json -p 80:80 -p 443:443 -p 2020:2020 --rm caddy
FROM caddy:2-alpine
RUN apk --no-cache add curl
EXPOSE 80 443 2020
admin localhost:2020
centige.site {
redir https://centige.com permanent
test.centige.site {
reverse_proxy https://xxxx.s3.amazonaws.com
rewrite * https://xxxx.s3.amazonaws.com/{uri}
I would like to remotely configure my Caddy server using something like api.centige.site.
I tried adding the following block, but it didn’t solve my problem:
api.centige.site {
reverse_proxy localhost:2020
Then I tried setting the admin endpoint to api.centige.site:2020, but running Caddy failed.
The port 2020 is already exposed in my AWS EC2 security group.
I am not sure if what I’m doing is possible. If it is, I’d really appreciate it if I can get any sort of help : )
Connecting to api.centige.site:2020 or EC2_IP:2020 in Insomnia resulted in Error: Couldn't connect to server.
Using curl returns connection refused.
oops, I already described this in 3)
A similar implementation to what I’m trying to do is GitHub Pages. They used to run on Nginx and reload the config every 30 min (Rearchitecting GitHub Pages - The GitHub Blog). I’d like to do the same thing, except, instead of reloading the config using a cron job, I can update it remotely.
PS. thank you for the awesome work ![]()
