I’m trying to strip / redact certain Headers values, but it seems it’s not working.
No error and the logs are ok.
Downloaded from Debian 12 repository.
caddy/now 2.7.6 amd64 [installed,local]
Caddy - Powerful, enterprise-ready, open source web server with automatic HTTPS written in Go
Debian 12
From the service
order coraza_waf first
:8443 {
tls /home/user/.caddy/certs/cert.pem /home/user/.caddy/certs/key.pem
file_server {
root /home/user/.caddy/pages/
handle_errors {
rewrite * /home/user/.caddy/pages/{err.status_code}.html
@validHost {
header Host gateway.x.com
@newHost {
header Host chat.x.com
route @newHost {
header Host "chat.x.com"
reverse_proxy https://chat-server.internal.lan {
header_up CF-*
header_up Cf-*
route @validHost {
coraza_waf {
load_owasp_crs
directives `
Include @coraza.conf-recommended
Include @crs-setup.conf.example
Include @owasp_crs/*.conf
SecRuleEngine Off
route /guacamole/* {
header Host "guacamole.internal.lan"
reverse_proxy http://guacamole.internal.lan:8080 {
header_up CF-*
header_up Cf-*
route /board/* {
header Host "chat-server.internal.lan"
uri strip_prefix /board
reverse_proxy https://chat-server.internal.lan:8443 {
header_up CF-*
header_up Cf-*
route /vault/* {
header Host "vault.internal.lan"
uri strip_prefix /vault
reverse_proxy https://vault.internal.lan {
header_up CF-*
header_up Cf-*
route /siem/* {
header Host "siem.internal.lan"
reverse_proxy https://siem.internal.lan:5601 {
header_up CF-*
header_up Cf-*
route /uptime/* {
header_up CF-*
header_up Cf-*
format filter {
wrap json
fields {
request>headers>Cf-Connecting-Ip delete
request>headers>Cf-Ipcountry delete
output file /home/user/.caddy/access.log {
roll_keep_for 24h
roll_keep 2
-Server
-Alt-Svc
Server "MyRevProxy/1.0.0-beta"
Strict-Transport-Security max-age=63072000;includeSubDomains;preload
X-Frame-Options SAMEORIGIN
X-Robots-Tag none
NOTE: I use coraza waf, but it is disabled at the moment of testing.
I alos tried request>headers>Cf-Connecting-Ip>[0] delete
, but didn’t work.
I used the official docs, questions and answers from this forum as well.
Do you guys have any advice? Thanks in advance.
In the logs it still shows inside the json as:
"X-Forwarded-For": [
"172.71.114.154"
"Cf-Connecting-Ip": [
"x.x.x.x"
"Sec-Fetch-Site": [
"none"
"Priority": [
"u=0, i"
