I’m trying to prioritize routing to a WS route before then routing to a catch all API route. With my current config, it sometimes does connect to the WS, and sometimes tries to connect to the catch-all server seemingly randomly.
caddy-1 | {"level":"error","ts":1714325787.625634,"logger":"http.log.error","msg":"dial tcp 64.70.19.33:80: i/o timeout","request":{"remote_ip":"MY.IP.ADDRESS","remote_port":"40394","client_ip":"MY.IP.ADDRESS","proto":"HTTP/1.1","method":"GET","host":"botrisbattle.com","uri":"/ws?token=ebb90df6-a63f-41f3-8fe5-ece02bebe8c7&roomKey=ssheavwg5qf1swre1w0kos4c","headers":{"Origin":["https://botrisbattle.com"],"Sec-Websocket-Key":["IEyrb3q3fvoXaVHEkLEOhQ=="],"Sec-Websocket-Version":["13"],"Connection":["Upgrade"],"Upgrade":["websocket"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"botrisbattle.com"}},"duration":3.000491934,"status":502,"err_id":"ca1uysd81","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
caddy-1 | {"level":"error","ts":1714325870.6034312,"logger":"http.log.error","msg":"dial tcp 64.70.19.33:80: i/o timeout","request":{"remote_ip":"MY.IP.ADDRESS","remote_port":"47460","client_ip":"MY.IP.ADDRESS","proto":"HTTP/1.1","method":"GET","host":"botrisbattle.com","uri":"/ws?roomId=mj089eig&spectate=true","headers":{"Sec-Websocket-Version":["13"],"Sec-Websocket-Extensions":["permessage-deflate"],"Sec-Websocket-Key":["ge5QDwqSVs76rb+yFnmjIA=="],"Connection":["keep-alive, Upgrade"],"User-Agent":["Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:125.0) Gecko/20100101 Firefox/125.0"],"Cookie":[],"Sec-Fetch-Dest":["empty"],"Sec-Fetch-Mode":["websocket"],"Upgrade":["websocket"],"Accept-Language":["en-US,en;q=0.5"],"Origin":["https://botrisbattle.com"],"Pragma":["no-cache"],"Accept":["*/*"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Site":["same-origin"],"Cache-Control":["no-cache"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"http/1.1","server_name":"botrisbattle.com"}},"duration":3.001959266,"status":502,"err_id":"f914xhw4g","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
caddy-1 | {"level":"error","ts":1714325876.7496252,"logger":"http.log.error","msg":"dial tcp 64.70.19.33:80: i/o timeout","request":{"remote_ip":"MY.IP.ADDRESS","remote_port":"36690","client_ip":"MY.IP.ADDRESS","proto":"HTTP/1.1","method":"GET","host":"botrisbattle.com","uri":"/ws?roomId=mj089eig&spectate=true","headers":{"User-Agent":["Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:125.0) Gecko/20100101 Firefox/125.0"],"Accept":["*/*"],"Origin":["https://botrisbattle.com"],"Cache-Control":["no-cache"],"Accept-Language":["en-US,en;q=0.5"],"Sec-Websocket-Key":["frKS0AFJmv0uVBSiNojkIA=="],"Connection":["keep-alive, Upgrade"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Dest":["empty"],"Sec-Fetch-Site":["same-origin"],"Pragma":["no-cache"],"Upgrade":["websocket"],"Sec-Websocket-Version":["13"],"Sec-Websocket-Extensions":["permessage-deflate"],"Cookie":[],"Sec-Fetch-Mode":["websocket"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"http/1.1","server_name":"botrisbattle.com"}},"duration":3.000643678,"status":502,"err_id":"pg2qkww33","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
Using a docker image
Docker, Debian 12
I run it through a docker container
image: caddy:2.7.6
- ./site:/srv
- caddy_data:/data
- caddy_config:/config
- frontend
image: caddy:2.7.6
- ./site:/srv
- caddy_data:/data
- frontend
server:
container_name: server
env_file:
- .prod.env
NUXT_BUILD: "false"
NODE_ENV: "production"
NUXT_ENVIRONMENT: "production"
build:
context: .
- 8080:8080
depends_on:
db:
condition: service_healthy
- frontend
db:
container_name: db
image: mysql
MYSQL_DATABASE: "botris"
MYSQL_ROOT_PASSWORD: "password"
# MYSQL_USER: "root"
# MYSQL_PASSWORD: "password"
# MYSQL_DATABASE: "database"
- db:/var/lib/botris-db
healthcheck:
test: ["CMD", "mysqladmin" ,"ping", "-h", "localhost"]
timeout: 20s
retries: 10
- frontend
db:
caddy_data:
caddy_config:
frontend:
botrisbattle.com {
@websockets {
header Connection *Upgrade*
header Upgrade websocket
handle /ws {
reverse_proxy @websockets /ws server:8080
reverse_proxy server:3000
