v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
systemd
centos 8, systemd 239-45.el8_4.3, kernel 4.18.0-305.12.1.el8_4.x86_64
systemctl reload caddy
or
systemctl restart caddy
because reload command often hangs and fails
# caddy.service
# for your installation.
Type=notify
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile
gitea.moe {
import logto gitea.moe
header /gitea.moe/css/raw/branch/master/custom.css Content-Type "text/css; charset=utf-8"
reverse_proxy localhost:3400
*.gitea.moe {
import dns-cloudflare-token
@rw {
header_regexp host Host ^(\w+)\.gitea\.moe$
path_regexp path ^\/([^\/]+)\/(.*)
rewrite @rw /{re.host.1}/{re.path.1}/raw/branch/master/{re.path.2}
header *.html Content-Type "text/html"
header *.js Content-Type "text/js"
header *.css Content-Type "text/css"
reverse_proxy @rw localhost:3400 {
@nf {
status 404
handle_response @nf {
respond 404
I want the reverse proxy to override Content-Type headers from upstream, according to file extension at end of URL. I thought it should be as simple as header *.html Content-Type "text/html" but it’s not working at all; there is no change in response headers, with or without {defer}.
The first site block has been working for a while, but response has two Content-Type headers. It works so I don’t care, but thought it’s worth mentioning. I am working on the second block.
How should I rewrite response headers with reverse_proxy? Am I doing it wrong, or am I encountering bugs?
I only have this for the issue with one of the things I tried below.
Oct 06 20:23:14 avps.owo69.me systemd[1]: Reloading Caddy.
Oct 06 20:23:14 avps.owo69.me caddy[3605456]: {"level":"info","ts":1633569794.9079423,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter"
Oct 06 20:23:14 avps.owo69.me caddy[3605456]: reload: adapting config using caddyfile: parsing caddyfile tokens for 'header': /etc/caddy/misc-sites.Caddyfile:45 - Error during
parsing: cannot specify headers in both arguments and block
Oct 06 20:23:14 avps.owo69.me systemd[1]: caddy.service: Control process exited, code=exited status=1
Oct 06 20:23:14 avps.owo69.me systemd[1]: Reload failed for Caddy.
I have tried them with {defer}, which I thought would have been needed. But it makes no difference for the second block, and for the first site block, makes it not work either.
I have also tried the following to delete and then add the header, but I got the error “cannot specify headers in both arguments and block”, which makes no sense because there weren’t any headers in arguments:
I also tried putting the header directives in a route{}.
wat
