1. Output of caddy version
In docker see below.
Running in Docker on Ubuntu 18.04
See the docker compose file below.
version: 3.5
image: caddy
- 443:443
- 2019:2019
- /opt/caddy/Caddyfile:/etc/caddy/Caddyfile
- /opt/caddy/data:/data
- /opt/caddy/config:/config
- internal
command: [ "caddy", "run", "--watch", "--config", "/etc/caddy/Caddyfile", "--adapter", "caddyfile" ]
output stdout
(auth) {
forward_auth authelia:9091 {
uri /api/verify?rd=https://auth.example.com/
copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
import /config/caddy/caddylocal.conf
import /config/caddy/caddymini.conf
I have included the --watch flag in my docker compose file and I believe this works if the main Caddyfile is updated, however it doesn’t monitor the imported config files, is there a way to watch these too? I am using docker-gen to generate these files, one is based on the local docker instance and one is based on a remote one. The config files work fine and if I do a docker exec caddy caddy reload --config /etc/caddy/Caddyfile
then everything loads up ok.
If there isn’t a way to monitor the imported files is there a way to issue a curl command to reload the config? I’ve been looking at the api and I can’t see a way to tell it to reload the config from the filesystem.
I have also looked at initiating a docker exec from docker-gen but because it needs to create the command then start it, this is getting beyond a one shot approach and might need some command line pipeing that is a bit beyond me.
No errors in log file.
See section 3
