How to match files for cache-control in a handler
I am trying to set a cache-control header based on a file type in a path. I tried this:
But putting this within the handler didn’t work and of course this is a reverse_proxy so it needs to be header_down. If I use this, it works but of course for all files which is not what I want.
@nocache {
        file *.txt
                reverse_proxy https://192.168.73.49:8080 {
                                dial_timeout 30s # Experimental
                                tls_insecure_skip_verify
	header_down cache-control no-store
The path in question is https://tester1.camdenacres.stream/static/status.txt
Things I have tried:
@nocache {
        file
        path *.txt
	header_down @nocache cache-control no-store
@nocache {
        file *.txt
Several other permutations.
N/A - This is a config issue.
Docker compose
version: "3.6"
  Caddy:
    container_name: "Caddy"
    hostname: "Caddy"
    image: "caddy:latest"
    logging:
      driver: "json-file"
      options:
        max-size: "100m"
      - "Docker1"
      - "443:443/tcp"
      - "80:80/tcp"
    restart: "unless-stopped"
      - "/opt/caddy/html:/var/caddy/html:ro"
      - "/opt/caddy:/etc/caddy:ro"
  Docker1:
    external: true
Debian 11.7 running Docker 23.0.1
See docker-compose aobve
See above
https://tester1.camdenacres.stream {
        handle_path /errors* {
                root * /var/caddy/html
	@nocache {
	        file *.txt
        handle_errors {
                @502 `{err.status_code} == 502`
 		handle @502 {
                        rewrite * /502.html
Use the header directive, not the header_down option of reverse_proxy.
The directive supports matchers, the proxy option does not.
Also, you’re looking for the path matcher, not file. The file matcher looks for a file existing on disk, but Caddy doesn’t have access to files in your setup since it’s proxying to a remote server.
I had a response and I think I see the issue as I misunderstood what you meant.
@nocache {
        path *.txt
                        header @nocache cache-control no-store
This seems to work betterish - but I have two cache-control headers now. So at least I know the match is working but I would expect the other cache-control to have been replaced with no-store. Example:
curl -I https://tester1.camdenacres.stream/static/status.txt
HTTP/2 200
accept-ranges: bytes
alt-svc: h3=":443"; ma=2592000
cache-control: no-store
cache-control: public, max-age=2678400
content-type: text/plain
date: Tue, 16 May 2023 01:24:58 GMT
etag: "175f769c838c22ab-271"
last-modified: Tue, 16 May 2023 00:00:01 GMT
server: Caddy
server: Python/3.10 aiohttp/3.8.4
content-length: 625
Note "cache-control: public, max-age=2678400 ".
EDIT: I tried
header @nocache cache-control public* no-store
and that seemingly didn’t match the exisiting header.
What you can do is use the defer option of the header directive to make sure it operates after the proxy, so it will overwrite it instead of letting the proxy add its own afterwards.
@nocache path *.txt
header @nocache {
	Cache-Control no-store
	defer
Brilliant, that worked perfectly. Thank you!
FWIW I’m thinking of adding a shortcut for that case because I’m a bit annoyed by the longer syntax :sweat_smile:
LGTM! Ship it. :slight_smile:
