k_o
(Karsten)
December 30, 2023, 8:45pm
1
I need to setup a h2c to h2c proxy with the goal to manipulate the requests and responses in a later step. No configuration I found works. What is the correct way to fulfill the first step of h2c ↔ h2c
127.0.0.200:7778
level debug
reverse_proxy {
to h2c://127.0.0.201:7777
versions h2c 2
Here I get no errors and not any output, the proxy seems to do nothing and the app request targeting the proxies are failing.
sudo caddy reverse-proxy -v --access-log --from h2c://127.0.0.200:7778 --to h2c://127.0.0.201:7777
But I get:
Caddy proxying h2c://127.0.0.200 → 127.0.0.201:7777
2023/12/30 20:39:11.455 DEBUG http.stdlib http: TLS handshake error from 127.0.0.1:36540: tls: first record does not look like a TLS handshake
Somehow caddy tries to use https although this is not the case.
sudo apt-get install caddy
Ubuntu 22.04
or with the Daddyfile:
level debug
reverse_proxy {
versions h2c 2
Mohammed90
(Mohammed Al Sahaf)
December 31, 2023, 12:04am
2
To enable h2c as the reverse_proxy transport, all you need is for the upstream address to have h2c://. You don’t need to manually configure the transport segment. More on this here:
To enable h2c on the server listener side, you need customize the enabled protocols list in the global options to have h2c. Caddy defaults to h1 h2 h3 because h2c is not encrypted so it’s not part of the default setup. See here:
k_o
(Karsten)
December 31, 2023, 1:11am
3
Thanks for the quick reply. I’m now using this and get a different error:
admin off
log default {
level debug
output stdout
format console
servers :7778 {
protocols h2c
:7778 {
bind 127.0.0.200
reverse_proxy * h2c://127.0.0.201:7777 {
log default {
level debug
output stdout
format console
I get in caddy:
2023/12/31 01:05:25.180 DEBUG http.handlers.reverse_proxy selected upstream {“dial”: “127.0.0.201:7777”, “total_upstreams”: 1}
2023/12/31 01:05:25.180 DEBUG http.handlers.reverse_proxy upstream roundtrip {“upstream”: “127.0.0.201:7777”, “duration”: 0.000479471, “request”: {“remote_ip”: “127.0.0.1”, “remote_port”: “36684”, “client_ip”: “127.0.0.1”, “proto”: “HTTP/2.0”, “method”: “PRI”, “host”: “”, “uri”: ““, “headers”: {“X-Forwarded-Proto”: [“http”], “X-Forwarded-Host”: [”“], “User-Agent”: [”"], “X-Forwarded-For”: [“127.0.0.1”]}}, “error”: “http2: Transport: cannot retry err [stream error: stream ID 3; PROTOCOL_ERROR; received from peer] after Request.Body was written; define Request.GetBody to avoid this error”}
2023/12/31 01:05:25.181 ERROR http.log.error.default http2: Transport: cannot retry err [stream error: stream ID 3; PROTOCOL_ERROR; received from peer] after Request.Body was written; define Request.GetBody to avoid this error {“request”: {“remote_ip”: “127.0.0.1”, “remote_port”: “36684”, “client_ip”: “127.0.0.1”, “proto”: “HTTP/2.0”, “method”: “PRI”, “host”: “”, “uri”: " ”, “headers”: {}}, “duration”: 0.000594763, “status”: 502, “err_id”: “u7td0w0b4”, “err_trace”: “reverseproxy.statusError (reverseproxy.go:1267)”}
2023/12/31 01:05:25.181 ERROR http.log.access.default handled request {“request”: {“remote_ip”: “127.0.0.1”, “remote_port”: “36684”, “client_ip”: “127.0.0.1”, “proto”: “HTTP/2.0”, “method”: “PRI”, “host”: “”, “uri”: “*”, “headers”: {}}, “bytes_read”: 0, “user_id”: “”, “duration”: 0.000594763, “size”: 0, “status”: 502, “resp_headers”: {“Server”: [“Caddy”]}}
I get in my app:
ERROR: [127.0.0.1]:55972 invalid frame (-532:Violation in HTTP messaging rule)
Since you’re using bind, you need to do servers 127.0.0.200:7778 to match the listener address.
Alternatively you can omit the listener address from the global option which will apply it to all servers (which is just the one in your case).
Also, if you set protocols to h2c, this also disables h1, h2 and h3 I think, which may be undesirable.
You can simplify this to just log (no options) which has the same effect. There’s no debug level access logs.
You can remove the { } braces here, they don’t do anything for you.
k_o
(Karsten)
December 31, 2023, 2:32am
5
Awesome! This works. Fastest community on this planet. Thanks Mohammed and Francis.
Here my working config as reference. I had to add also the h1 protocol
admin off
servers 127.0.0.200:7778 {
protocols h1 h2c
:7778 {
bind 127.0.0.200
log default
