How to make a reverse proxy on a specific route properly?
I’m trying to make a reverse proxy to localhost on a specific route in my app. Let’s say we have a route named /app that should forward to localhost:3000 with the following code:
localhost {
  handle /app {
    reverse_proxy: http://localhost:3000
Then caddy forwards /app to my app while it expects / to be the root. I tried to use the strip_prefix function like this:
localhost {
  handle /app {
    uri strip_prefix /app
But then redirects don’t work. Should I do something to fix them or does caddy have some more built in way to handle this better?
Not relevant
Not relevant
Not relevant
Not relevant
Already mentioned
I’d say it’s relevant because I don’t think that reverse_proxy: syntax you’re using it correct.
Ah sorry i typed it wrong, it was not like that in my real code.
See this article
