My task is to limit the number of external connections for the site to 10. At the same time, the restriction should not work for local network. Thanks
Caddy v2.6.2 on CentOS7
That’s not something included in the vanilla distribution of Caddy.
You can implement this yourself if you need it, probably as a listener wrapper module.
Thank you!
