Dynamically populated “handle” array within a server directive is difficult to manage. For example add 100 items, then i want to edit item 52. Using the @id tag is unreliable because Caddy allows me to add multiple identical @id values.
I’m looking for something like a key/value reference that I can later re-visit to update a setting down the line.
n/a
3. Caddy version: 2.7.5
4. How I installed and ran Caddy: apt
a. System environment: Ubuntu
/usr/bin/caddy run --environ --config /etc/caddy/config.json
Type=notify
ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/config.json
ExecReload=/usr/bin/caddy reload --config /etc/caddy/config.json --force
"apps": {
"http": {
"http_port": 8080,
"https_port": 4343,
"servers": {
"srv0" : {
"listen" : [":8080"],
"routes" : []
