You’re running the cache in debug mode (log_level debug
directive).
About the hit TTL issue, I can’t explain that and I don’t know how to reproduce because on the CI tests I ensure the computed TTL is the right one.
Use the log
directive with no block/options inside of your site, which makes the logger write to the default
logger.
In your global options you configured the global logger (by not providing a name) which writes to an access.log
file, which is named incorrectly because the default logger doesn’t write access logs (unless you use the log
directive inside of a site – it configures runtime logs, i.e. everything else).
Look for http.log.access
logs, which are access logs. They should be written for all requests, even ones which the cache
module intercepts.
I bamboozled myself.
I did run caddy via caddy run --config /etc/caddy/Caddyfile
and then pressed ctrl+c so I could faster test different configs but I did not notice that if caddy did not cleanly shutdown the next instance would happily start even though there was already one caddy instance running.
First I did expect that ctrl+c would actually kill it and second that it would instead of starting error out with port is already in use both is not the case.
That explains also why I got different ttls and requests would not end up in the log, they were answered by a instance with a much older config.
I’m very sorry and thank you everybody for your help.
Since I did ask multiple questions and the thread title is not really suiting all this anymore I will post here my complete webserver configs I run currently if somebodys finds this via google.
Please be aware this is configured to my personal taste and may doesn’t make sense in a future (also I run this on a pretty slow OpenWRT device, so I’m not even sure if this would work on a Debian or CentOS), so it is more a start point for a personal config and less suited to use as copy and paste.
caddyfile
# Caddy binary download from https://caddyserver.com/download with cache-handler and brotli
admin off
cache
order cache before rewrite
http:// {
bind unix//tmp/caddy|600
cache {
#log_level debug
ttl 168h
stale 168h
#mode bypass
#default_cache_control public
timeout {
backend 1m
cache 1m
encode {
br 11
#header -Cache-Control
#header Cache-Control max-age=604800
reverse_proxy {
# verbose_logs
# header_down -Cache-Control
# header_up -Cache-Control
to 10.0.5.2:32400
my nginx is build with headers more and quic
add to your nginx.conf
http {
# Keep alive setting
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
nginx vhost
upstream plex {
server 10.0.5.2:32400;
keepalive 120;
upstream caddy {
server unix:/tmp/caddy;
keepalive 120;
server {
listen 443 ssl;
listen 443 quic;
listen [::]:443 ssl;
listen [::]:443 quic;
add_header Alt-Svc 'h3=":443"; ma=86400' always;
server_name plex.lan;
##cert
#ECC
ssl_certificate /var/acme/plex.lan_ecc/fullchain.cer;
ssl_certificate_key /var/acme/plex.lan_ecc/plex.lan.key;
#RSA
ssl_certificate /var/acme/plex.lan/fullchain.cer;
ssl_certificate_key /var/acme/plex.lan/plex.lan.key;
##Header
#HSTS
add_header Strict-Transport-Security "max-age=63072000; includeSubDomains; preload" always;
# Security / XSS Mitigation Headers
add_header X-Frame-Options "SAMEORIGIN";
add_header Referrer-Policy "same-origin";
add_header X-XSS-Protection "1; mode=block";
add_header X-Content-Type-Options "nosniff";
#No Searchengine Index
add_header X-Robots-Tag "noindex, nofollow, nosnippet, noarchive" always;
##OCSP settings
ssl_stapling on;
location ~* \.(?:css|js|json)$ {
proxy_set_header Host Plex;
proxy_pass_request_headers off;
proxy_set_header Accept-Encoding $http_accept_encoding;
proxy_set_header Pragma $http_pragma;
proxy_pass http://caddy;
proxy_request_buffering off;
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
proxy_max_temp_file_size 0;
proxy_redirect off;
proxy_buffering off;
location / {
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
#proxy_set_header X-Real-IP $remote_addr;
#proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass http://plex;
proxy_set_header Accept-Encoding "";
proxy_set_header Connection "";
proxy_set_header Sec-WebSocket-Extensions $http_sec_websocket_extensions;
proxy_set_header Sec-WebSocket-Key $http_sec_websocket_key;
proxy_set_header Sec-WebSocket-Version $http_sec_websocket_version;
proxy_redirect off;
Thank you francislavoie and darkweak for all your help
I’m not sure why you’re using nginx at all in this setup, you could do all that with just Caddy, with way less config, and with TLS automation built in.
