I am using the latest version, Caddy 2.x, freshly downloaded from github.
MacOS 10.14.6
# Caddyfile
localhost {
reverse_proxy localhost:9000
How do I implement and enforce mutual-TLS?
Caddy already enforces HTTPS for server authentication. That half is working fine. But how do I enforce mutual-TLS for client authentication?
In my configuration, Caddy is acting as a reverse-proxy, for my custom back-end REST-API server written in Go.
Do I need to implement the client authentication in my own server ?? If yes, then I would appreciate pointers to example code.
Can Caddy do the client authentication for me ?? If this is possible, I would appreciate pointers to example code and/or configuration examples.
This isn’t working yet, so there are no error messages.
I was not able to find any online examples or documentation that show how to make mutual-TLS work with Caddy.
