1. caddy:2.4.2-alpine
I run caddy as docker container
CMD ["caddy", "run"]
localhost:80, home.so: {
route * {
geoip '/etc/caddy/databases/geo.mmdb'
reverse_proxy http://192.168.1.101:3000 {
header_up custom-header test
header_up Country-Name {geoip_country_name}
I wanna get the user country name based on their request and pass it to the upstream as a header. i am trying to use this plugin but it does not work, also I saw in the portal that some people said about building geo-ip not sure if this still exists in v2. however, when I use that plugin I get errors. I am most wondering
how can i do this in Caddy v2?
fyi, the path of db is correct
2021/11/04 12:53:07.424 INFO using adjacent Caddyfile
2021/11/04 12:53:07.426 WARN input is not formatted with 'caddy fmt' {"adapter": "caddyfile", "file": "Caddyfile", "line": 1}
2021/11/04 12:53:07.431 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["[::1]:2019", "127.0.0.1:2019", "localhost:2019"]}
2021/11/04 12:53:07.432 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00048a000"}
2021/11/04 12:53:07.432 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/11/04 12:53:07.432 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2021/11/04 12:53:07.432 INFO http server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server {"server_name": "srv1", "http_port": 80}
2021/11/04 12:53:07.432 INFO tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc00048a000"}
run: loading initial config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 0: loading handler modules: position 0: loading module 'geoip': provision http.handlers.geoip: geoip: Can't open database: '/etc/caddy/databases/geo.mmdb'
