Title explains itself(mostly). I’m trying to connect to a Jellyfin server, but it won’t. The setup and all can be found below:
Freenom Setup
- Using Freenom Name Servers, with the following for Freenom DNS:
– Name www, Type A, TTL 3600, Target my public ip address - Nothing is set up under “Register glue records” or “URL Forwarding”
Caddyfile Configuration
email *my.email.com*
*my.domain.com* {
output file /etc/caddy/logs/jellyfin_access.log {
roll true # Rotate logs, enabled by default
roll_size_mb 5 # Set max size 5 MB
roll_gzip true # Whether to compress rolled files
roll_local_time true # Use localhost time
roll_keep 2 # Keep at most 2 log files
roll_keep_days 7 # Keep log files for 7 days
redir /jellyfin /jellyfin/
reverse_proxy /jellyfin/* 127.0.0.1:*port*
# Edit 05/06/20 Remove Empty Brackets, Change logging format, and added Email portion. Commented out email portion for now
# Edit 05/07/20 Removed Email portion. Adding an optional part in the guide for it.
# Proof /u/NoFeedback4007 is original author. :)
I didn’t think the template was necessary in any way here, if it would really be preferred/necessary to use it, let me know.
