How to get a true remote IP behind caddy reverse proxy
The service behind caddy reverse proxy can NOT obtain true IP.
e.g.
  1. I have a server (IP 192.168.50.32), which is deploied the docker.
  2. The docker has two network mode: host and bridge(IP CIDR 172.17.0.0/20, Gateway 172.17.0.1)
  3. A Caddy docker is run using bridge (IP 172.17.0.5), which be set as a reverse proxy, 192.168.50.32:58443–>172.17.0.5:443
  4. A DDNS-GO docker is run using host, 192.168.50.32:9876
  5. A local network machine as terminal (IP 192.168.50.151)
  6. I expect machine access DDNS-GO via caddy, and DDNS-GO will obtain remote IP is 192.168.50.151, but now that is docker gateway IP 172.17.0.1
when I access ddns-go:
% curl -4vL https://app-ddnsgo.direct.do.main:58443/
*   Trying 192.168.50.32:58443...
* Connected to app-ddnsgo.direct.do.main (192.168.50.32) port 58443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  subject: CN=*.direct.do.main
*  start date: Jan 13 00:00:00 2024 GMT
*  expire date: Apr 12 23:59:59 2024 GMT
*  subjectAltName: host "app-ddnsgo.direct.do.main" matched cert''s "*.direct.noipto.host"
*  issuer: C=AT; O=ZeroSSL; CN=ZeroSSL ECC Domain Secure Site CA
* Using Stream ID: 1 (easy handle 0x7f9e2400b600)
> GET / HTTP/2
> Host: app-ddnsgo.direct.do.main:58443
> user-agent: curl/7.80.0
> accept: */*
< HTTP/2 403
< date: Mon, 15 Jan 2024 19:29:50 GMT
< server: Caddy
< content-length: 0
* Connection #0 to host app-ddnsgo.direct.do.main left intact
This is caddy access log:
    "level": "error",
    "ts": 1705346990.384408,
    "logger": "http.log.access.log0",
    "msg": "handled request",
    "request": {
        "remote_ip": "172.17.0.1",
        "remote_port": "36576",
        "client_ip": "172.17.0.1",
        "proto": "HTTP/2.0",
        "method": "GET",
        "host": "app-ddnsgo.direct.do.main:58443",
        "uri": "/",
        "headers": {
            "User-Agent": [
                "curl/7.80.0"
            "Accept": [
        "tls": {
            "resumed": false,
            "version": 772,
            "cipher_suite": 4865,
            "proto": "h2",
            "server_name": "app-ddnsgo.direct.do.main"
    "bytes_read": 0,
    "user_id": "",
    "duration": 0.00053049,
    "size": 0,
    "status": 403,
    "resp_headers": {
        "Server": [
            "Caddy"
        "Alt-Svc": [
            "h3=\":443\"; ma=2592000"
        "Date": [
            "Mon, 15 Jan 2024 19:29:50 GMT"
        "Content-Length": [
            "0"
This is ddns-go access log
	2024/01/16 03:29:50 "Remote: 172.17.0.5:49442 ,Real-IP: 172.17.0.1:36576 ,Forwarded-For: 172.17.0.1:36576" prohibit acess from WAN
docker compose
caddy run --config /etc/caddy/Caddyfile
    container_name: Caddy
    image: caddy:latest
    restart: always
    network_mode: bridge
      - "58443:443"
      - "58443:443/udp"
      - /etc/localtime:/etc/localtime
      - ./caddy/data:/data
      - ./caddy/config:/config
*.direct.do.main {
	@app-ddnsgo {
	reverse_proxy @app-ddnsgo http://192.168.50.32:9876 {
		header_up Host {host}
		header_up X-Real-IP {remote}
		header_up X-Forwarded-For {remote}
        header_up X-Forwarded-Port {server_port}
        header_up X-Forwarded-Proto "http"
		trusted_proxies 172.17.0.0/20
I try to comment Line 6-11 arbitrarily, but the reponse is NOT meet expectation.
None of this is useful in your case. You can remove all this.
Your problem is that Docker sometimes uses a userland-proxy, i.e. acts as a TCP-layer proxy in front of Caddy, which means the source IP is lost.
This isn’t a Caddy problem, but rather a Docker problem. This is a long-standing issue with Docker, for example Document how to get real remote client ip for service running in container · Issue #15086 · moby/moby · GitHub
Does this mean that if I install caddy without docker, the default reverse proxy can deliver true source IP, so I don’t need to extra caddyfile configuration?
Yes, running Caddy on the host (not in Docker) is one way to solve it.
I tried to running Caddy docker as network mode host, and modify caddy’s listen port, now it works!! The true source IP is shown in the service.
