How to force ACME for subdomains when a wildcard Cloudflare Origin Certificate is loaded?
I am trying to use a manually loaded Cloudflare Origin wildcard certificate for my root domain (example.com), while using Caddy’s automatic HTTPS (via Let’s Encrypt and the DNS-01 challenge) for my subdomains (git.example.com and board.example.com).
Because the manually loaded certificate is a wildcard (*.example.com), Caddy’s auto-HTTPS logic determines that a valid certificate is already in memory for those subdomains. As a result, it completely skips the automatic certificate management for the subdomains, and no Let’s Encrypt certificates are requested. I am looking for a way to force Caddy to fetch ACME certificates for the subdomains and ignore the loaded wildcard cert for those specific blocks.
caddy | { level: "info", ts: 1771844438.8848627, msg: "maxprocs: Leaving GOMAXPROCS=1: CPU quota undefined" } [cite: 4]
caddy | { level: "info", ts: 1771844438.886466, msg: "GOMEMLIMIT is updated", package: "github.com/KimMachineGun/automemlimit/memlimit", GOMEMLIMIT: 876817612, previous: 9223372036854775807 } [cite: 5]
caddy | { level: "info", ts: 1771844438.887361, msg: "using config from file", file: "/etc/caddy/Caddyfile" } [cite: 6]
caddy | { level: "info", ts: 1771844438.8901865, msg: "adapted config to JSON", adapter: "caddyfile" } [cite: 7]
caddy | { level: "warn", ts: 1771844438.8924909, msg: "Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies", adapter: "caddyfile", file: "/etc/caddy/Caddyfile", line: 2 }
caddy | { level: "info", ts: 1771844438.897751, logger: "admin", msg: "admin endpoint started", address: "localhost:2019", enforce_origin: false, origins: ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"] } [cite: 9]
caddy | { level: "warn", ts: 1771844438.9052832, logger: "tls", msg: "stapling OCSP", error: "no OCSP stapling for [cloudflare origin certificate *.example.com example.com]: no URL to issuing certificate" } [cite: 10]
caddy | { level: "info", ts: 1771844438.9107153, logger: "http.auto_https", msg: "skipping automatic certificate management because one or more matching certificates are already loaded", domain: "example.com", server_name: "srv0" } [cite: 11]
caddy | { level: "info", ts: 1771844438.9120688, logger: "http.auto_https", msg: "skipping automatic certificate management because one or more matching certificates are already loaded", domain: "*.example.com", server_name: "srv0" } [cite: 12]
caddy | { level: "info", ts: 1771844438.9128053, logger: "http.auto_https", msg: "enabling automatic HTTP->HTTPS redirects", server_name: "srv0" } [cite: 13]
caddy | { level: "info", ts: 1771844438.914895, logger: "http", msg: "enabling HTTP/3 listener", addr: ":443" } [cite: 14]
caddy | { level: "info", ts: 1771844438.922761, msg: "failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details." } [cite: 15]
caddy | { level: "info", ts: 1771844438.924708, logger: "http.log", msg: "server running", name: "srv0", protocols: ["h1", "h2", "h3"] } [cite: 16]
caddy | { level: "warn", ts: 1771844438.9283235, logger: "http", msg: "HTTP/2 skipped because it requires TLS", network: "tcp", addr: ":80" } [cite: 17]
caddy | { level: "warn", ts: 1771844438.928646, logger: "http", msg: "HTTP/3 skipped because it requires TLS", network: "tcp", addr: ":80" } [cite: 18]
caddy | { level: "info", ts: 1771844438.9292579, logger: "http.log", msg: "server running", name: "remaining_auto_https_redirects", protocols: ["h1", "h2", "h3"] } [cite: 19]
caddy | { level: "info", ts: 1771844438.9316483, msg: "autosaved config (load with --resume flag)", file: "/config/caddy/autosave.json" } [cite: 20]
caddy | { level: "info", ts: 1771844438.933737, msg: "serving initial configuration" } [cite: 21]
caddy | { level: "info", ts: 1771844438.9080808, logger: "tls.cache.maintenance", msg: "started background certificate maintenance", cache: "0x15c594025200" } [cite: 22]
caddy | { level: "info", ts: 1771844438.9354918, logger: "tls", msg: "storage cleaning happened too recently; skipping for now", storage: "FileStorage:/data/caddy", instance: "e836ae62-4494-4910-bdb4-a60d6cfaae7d", try_again: 1771930838.9354901, try_again_in: 86399.999999499 } [cite: 23]
caddy | { level: "info", ts: 1771844438.9355779, logger: "tls", msg: "finished cleaning storage units" } [cite: 24]
v2.10.2
Compiled it myself with cloudflare DNS plugin:
FROM caddy:builder AS builder
RUN xcaddy build --with github.com/caddy-dns/cloudflare
FROM caddy:alpine
CMD ["caddy", "run", "--config", "/etc/caddy/Caddyfile", "--adapter", "caddyfile"]
Debian 13, amd64, systemd, Docker
Docker service command: docker compose up -d
Inside container: caddy run --config /etc/caddy/Caddyfile --adapter caddyfile
    image: caddy-cloudflare:latest
    user: "1006:1006"
      - "443:443/udp"
      CLOUDFLARE_API_TOKEN: ${CLOUDFLARE_API_TOKEN}
(security_headers) {
        Strict-Transport-Security "max-age=15552000; includeSubDomains; preload"
        X-Frame-Options "SAMEORIGIN"
        Content-Security-Policy "upgrade-insecure-requests; frame-ancestors 'self'"
        Referrer-Policy "same-origin"
        -Server
        -X-Powered-By
(no_robots) {
    respond /robots.txt 200 {
        body "User-agent: *\nDisallow: /\n"
        close
example.com {
    tls /keys/cloudflare/origin.pem /keys/cloudflare/origin.key
    import security_headers
        output file /var/log/caddy/landing_access.log
        level INFO
    root * /static
    try_files {path} /index.html
*.example.com {
        resolvers 1.1.1.1
    import no_robots
        level INFO
    @git host git.example.com
    handle @git {
        reverse_proxy forgejo:3000
    @vikunja host board.example.com
    handle @vikunja {
        reverse_proxy vikunja:3456
        abort
You can do tls force_automate { ... }
Alright, Caddy successfully obtained a cert from Let’s Encrypt, but subdomains are still serving the Cloudflare Origin one
Why use the origin cert at all if you have DNS challenge set up? Cloudflare is happy to connect to a server with a publicly trusted Let’s Encrypt cert, so you can just let your example.com site use Let’s Encrypt.
It’s a tricky problem to solve in Caddy because technically it’s working as intended, your cert just has SANs that are wider than it should be, which is a TLS antipattern.
