V2.1.1
systemd and Caddyfile
Raspbian (Debian Buster)
n/a
n/a
chomsky.ddns.net
reverse_proxy 127.0.0.1:8096
I was having issues yesterday trying to log in to my server but today everythings seems to work again but i’m seeing an error. Yesterday I remember the error message ending with “broken pipe”
How can I resolve this?
Sep 16 23:40:59 raspberrypi caddy[564]: {“level”:“info”,“ts”:1600292459.1143682,“msg”:“autosaved config”,“file”:"/var/lib/caddy/.config/caddy/autosave.json"}
Sep 16 23:40:59 raspberrypi caddy[564]: {“level”:“info”,“ts”:1600292459.1147778,“msg”:“serving initial configuration”}
Sep 17 13:18:30 raspberrypi caddy[564]: {“level”:“error”,“ts”:1600341510.6164703,“logger”:“http.handlers.reverse_proxy”,“msg”:“aborting with incomplete response”,“error”:“http2: stream closed”}
Sep 17 13:18:43 raspberrypi caddy[564]: {“level”:“error”,“ts”:1600341523.4510076,“logger”:“http.handlers.reverse_proxy”,“msg”:“aborting with incomplete response”,“error”:“http2: stream closed”}
Sep 17 13:18:55 raspberrypi caddy[564]: {“level”:“error”,“ts”:1600341535.2542725,“logger”:“http.handlers.reverse_proxy”,“msg”:“aborting with incomplete response”,“error”:“http2: stream closed”}
Sep 17 13:22:04 raspberrypi caddy[564]: {“level”:“error”,“ts”:1600341724.532256,“logger”:“http.handlers.reverse_proxy”,“msg”:“aborting with incomplete response”,“error”:“http2: stream closed”}
Sep 17 14:10:30 raspberrypi caddy[564]: {“level”:“error”,“ts”:1600344630.2356837,“logger”:“http.handlers.reverse_proxy”,“msg”:“aborting with incomplete response”,“error”:“http2: stream closed”}
I’ve restarted the caddy.service and rebooted. Had a look if my ddns was up to date
