): V2
Docker official :latest
image: caddy
- /etc/docker/data/caddy/Caddyfile:/etc/caddy/Caddyfile
- /etc/docker/data/caddy/data:/data
- /etc/docker/data/caddy/config:/config
- 443:443
- 2015:2015
- ACME_AGREE=true
admin 0.0.0.0:2015
email w@swtk.info
(netMatchers) {
@internet {
not remote_ip 192.168.10.0/24 192.168.20.0/24 172.19.0.0/16
@local {
# LAN connection, unavailable from outside
(lanCore) {
level ERROR
@internet {
@local {
respond @internet 200
(lan) {
import lanCore
reverse_proxy @local {args.0}
(lan-skip-insecure) {
import lanCore
reverse_proxy @local {args.0} {
tls
tls_insecure_skip_verify
# internet connection
(internet) {
level ERROR
reverse_proxy {args.0}
# hosts
https://deluge.XXX.eu {
import lan deluge:8112
I expected that the configuration above will filter all logs below ERROR
for the site https://deluge.XXX.eu
. Indeed, when I connect to the site via my browser I do not see the connection logs.
When I connect via a program, however (specifically Python’s requests
- calling the same URL as above) I do get logs (they are below).
One of the logs is a full JSON one, and the other one just an access one. I wonder where the other one comes from - I know that this comes from a monitoring program I wrote and I see the logs for all sites that are monitored (such as the one in the example log), and then at the end that weird single line (in the same block of logs coming from the monitoring program)
{"level":"info","ts":1608739629.023793,"logger":"http.log.access","msg":"handled request","request":{"remote_addr":"172.19.0.1:41538","proto":"HTTP/1.1","method":"GET","host":"deluge.XXX.eu","uri":"/","headers":{"Accept":["*/*"],"Connection":["keep-alive"],"User-Agent":["python-requests/2.23.0"],"Accept-Encoding":["gzip, deflate"]}},"common_log":"172.19.0.1 - - [23/Dec/2020:16:07:09 +0000] \"GET / HTTP/1.1\" 308 0","duration":0.000042132,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Location":["https://deluge.XXX.eu/"],"Connection":["close"],"Content-Type":[]}}
172.19.0.1 - - [23/Dec/2020:16:07:09 +0000] "GET / HTTP/1.1" 405 178
I looked very much at the docs, then at the configuration, then at the logs again and then decided to post the question here
