How to exclude a path from forward_auth?
I am using Caddy with forward_auth with Authelia. For my Aria2 service, my Caddyfile is the following:
aria2.redacted.com {
	forward_auth authelia:9091 {
		copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
		uri /api/verify?rd=https://authelia.redacted.com/
	reverse_proxy /rpc/* aria2:6800
	reverse_proxy ariang:6880
AriaNG is the WebUI, Aria2 is the API accessible via RPC. I want AriaNG (so everything behind the subdomain) to be secured behind Authelia via forward_auth. But the subpath /rpc/* must not be included in the forward_auth, as RPC can’t connect.
Simply put, how can I exclude the path /rpc/* from forward_auth, while still including every other path and the base subdomain ?
Thanks in advance for any answer, have a great day.
v2.6.4
Caddy docker container
Docker, Raspberry Pi 4, LibreELEC.
@except not path /rpc/*
forward_auth @except authelia:9091 {
Or:
	handle /rpc/* {
		reverse_proxy aria2:6800
Hi, thanks a lot for your answer.
Excluding /rpc from forward_auth works.
But I’m having another issue. aria2.redacted.com correctly takes me to AriaNG, it is accessible.
But I can’t access Aria2 via RPC on aria2.redacted.com/rpc. I have this error in caddy:
ERR ts=1685480351.281639 logger=http.log.error msg=EOF request={"remote_ip":"192.168.1.1","remote_port":"56188","proto":"HTTP/2.0","method":"POST","host":"aria2.redacted.com","uri":"/rpc","headers":{"Accept-Encoding":["gzip, deflate, br"],"Content-Type":["application/json;charset=utf-8"],"Content-Length":["138"],"Dnt":["1"],"Cookie":[],"Sec-Fetch-Site":["same-origin"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/113.0"],"Accept":["application/json, text/plain, */*"],"Accept-Language":["fr-FR,fr;q=0.8,en-US;q=0.5,en;q=0.3"],"Origin":["moz-extension://48089e12-d1b6-4d96-b95d-41df98c36eb9"],"Sec-Fetch-Dest":["empty"],"Sec-Fetch-Mode":["cors"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"aria2.redacted.com"}} duration=30.22656849 status=502 err_id=tfpwe4iu0 err_trace=reverseproxy.statusError (reverseproxy.go:1299)
I’m not sure why Aria2 can’t be reached. Here is my Caddyfile:
	handle /rpc/* {
I tested locally and I can access Aria2 on my lan, meaning the port is 6800.
Could you help me to find what’s wrong ?
Thanks in advance and have a great day.
The matcher is /rpc/* but you made a request to /rpc which doesn’t have a trailing slash. If you need to match that, then use /rpc* instead.
Thanks for your answer.
I don’t understand why, but reverse proxying Aria2 to a completely different subdomain like this work:
ariang.redacted.com {
It works, but I would prefer to avoid using 2 subdomains. I prefer a single one and a subpath for aria2.
But this doesn’t:
	handle /rpc* {
I have no error appearing in caddy with this, and no error in ariang. It just doesn’t connect, I can’t see the difference between the two.
I don’t have enough details to go off of here. I don’t know what your applications are or what they’re doing. You also didn’t fill out the help topic template as per the forum rules. The template gives instructions for getting debug logs.
What would you need exactly to have more info?
I checked caddy, aria2 and ariang logs, I don’t see any error or warning. I’m not sure which one is in fault. But I’m available to send any necessary information.
What I just noticed though, is that aria2 rpc address is not aria2:6800 but aria2:6800/jsonrpc. Could this be an issue? I tried to connect to /rpc/jsonrpc but it doesn’t work either.
Like I said, debug logs. Turn on the debug global option, show all the logs you see from making a request.
Are you expecting /rpc to be stripped from the URL before proxying? If so use handle_path /rpc* instead of handle /rpc* which will strip off /rpc from the front of the URL. Or change your matcher to /jsonrpc* if that’s what you actually need to proxy.
