How to enable HTTPS on IP address (to test on mobile)?
I’ve been using Caddy for a bit for localhost development and it’s been fantastic. However, I’ve always used localhost. Now, I want to try out my webapp on mobile. However, it seems that I cannot access the webapp using my PC’s IP address, even from my PC.
I'm not too sure what logs to put here, if any.
v2.10.0
Windows 11, using Docker
Client:
 Cloud integration: v1.0.35+desktop.10
 Version:           25.0.3
 API version:       1.44
 Go version:        go1.21.6
 Git commit:        4debf41
 Built:             Tue Feb  6 21:13:02 2024
 OS/Arch:           windows/amd64
 Context:           default
Server: Docker Desktop 4.27.2 (137060)
 Engine:
  Version:          25.0.3
  API version:      1.44 (minimum version 1.24)
  Git commit:       f417435
  Built:            Tue Feb  6 21:14:25 2024
  OS/Arch:          linux/amd64
  Experimental:     false
 containerd:
  Version:          1.6.28
  GitCommit:        ae07eda36dd25f8a1b98dfbf587313b99c0190bb
 runc:
  Version:          1.1.12
  GitCommit:        v1.1.12-0-g51d5e94
 docker-init:
  Version:          0.19.0
  GitCommit:        de40ad0
docker compose -f .\docker-compose.dev.yml watch
  # My other apps
    image: caddy:latest
      - caddy-network
      - ./Caddyfile.dev:/etc/caddy/Caddyfile
      - caddy-data:/data
      - caddy-config:/config
  caddy-data:
  caddy-config:
  caddy-network:
192.168.1.30 being my PC’s IP address
And app being my webapp
localhost:443, 192.168.1.30:443 {
        encode
        reverse_proxy app:5173
You don’t need the :443 in the host name part because it’s the default when TLS is enabled. To have HTTPS on IP address, use tls internal as such:
localhost, 192.168.1.30 {
        tls internal
        encode
I removed it, thank you.
Unfortunately, adding tls internal didn’t change anything. I still get Secure Connection Failed in the browser.
Well, yeah, the certificate is not from a trusted authority. You have to bypass it. If you need a publicly trusted certificate, then you cannot use LAN IP address and only a limited set of certificate authorities provide IP certificates.
Well, that’s a bit disappointing. I’ll probably use a DDNS service to try out my webapp on mobile.
Thank you for your help.
