How to drop connection
I’m using caddy v2 as a reverse proxy for containers, and my host has many DNS aliases. I want to have a way to drop the connection for requests to DNS hostnames that are not in the caddyfile.
It seems that nginx has a specific magic trick to do it - nginx: How to drop connections for a location - makandra dev
(basically, respond with a status code that is invalid, and the socket is closed)
seeing How to drop request completely based on IP , I’m assuming this is not currently possible
so I wonder - would it make sense to have a cfg like:
respond * {
    close
as a fallback when no matchers have matched?
Well, if you’re using TLS, then Caddy will respond with a TLS handshake failure if it didn’t have an appropriate certificate. I assume the connection is closed automatically in those situations.
So it depends on how your Caddyfile is structured. Could you please share it, so we can discuss how that would look?
ah, I use wildcard certs, so that too doesn’t work.
My caddyfile is dynamic - its generated from container labels - but basically - I want to have a way to specify “if we match this” (or “if no match has been made”) close.
I’m aware that this isn’t identical to what would happen if there was nothing listening to the port, but its a start.
	admin 0.0.0.0:2019
	email sven@home.org.au
	debug true
(dns_api_gandi) {
		issuer acme {
			dns gandi {env.GANDIV5_API_KEY}
		issuer internal
*.loc.alho.st loc.alho.st {
	@testing_loc_alho_st {
		host testing.loc.alho.st
	import dns_api_gandi
	route @testing_loc_alho_st {
		respond Testing
        # <<<<<< HERE is where I'd like to say if nothing matched so far, just close
If I understand you correctly, Sven, then what you suggested:
respond {
    close
should do the trick. (I omitted the matcher, which you can add based on your requirements.)
I was pretty sure that’s what I tried first - so I re-ran it, and this gives me
[ERROR] Removing invalid block: parsing caddyfile tokens for ‘respond’: Caddyfile:135 - Error during parsing: Wrong argument count or unexpected line ending after ‘respond’
		respond Testing
	respond {
		close
yup, pushing boundaries :slight_smile:
Oh, right, a status code or response body is required. So something like respond 4xx should work (choose a status code of your choice).
sadly, no
dow184@township-sl:~/src/caddy$ curl -v https://nomatch.loc.alho.st/
*   Trying 10.10.10.174:443...
* TCP_NODELAY set
* Connected to nomatch.loc.alho.st (10.10.10.174) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
*  subject: CN=*.loc.alho.st
*  start date: Jan 13 02:28:11 2021 GMT
*  expire date: Apr 13 02:28:11 2021 GMT
*  subjectAltName: host "nomatch.loc.alho.st" matched cert's "*.loc.alho.st"
* Using Stream ID: 1 (easy handle 0x5650d865bdf0)
> GET / HTTP/2
> Host: nomatch.loc.alho.st
> user-agent: curl/7.68.0
> accept: */*
< HTTP/2 444
< server: Caddy
< content-length: 0
< date: Wed, 20 Jan 2021 00:42:02 GMT
* Connection #0 to host nomatch.loc.alho.st left intact
I want it to not reply especially with some form of http status code / http headers
just to close the socket.
I see… you will want to track this issue then:
https://github.com/caddyserver/caddy/issues/3871
