official docker container
Question
I have some very talkative servers I would like to quiet. An example of such a log is
"level": "info",
"ts": 1595748542.2592723,
"logger": "http.log.access",
"msg": "handled request",
"request": {
"method": "GET",
"uri": "/",
"proto": "HTTP/1.1",
"remote_addr": "172.19.0.1:52808",
"host": "elasticsearch.example.com:80",
"headers": {
"User-Agent": [
"Go-http-client/1.1"
"Accept": [
"application/json"
"Accept-Encoding": [
"gzip"
"common_log": "172.19.0.1 - - [26/Jul/2020:07:29:02 +0000] \"GET / HTTP/1.1\" 308 0",
"duration": 0.000081632,
"size": 0,
"status": 308,
"resp_headers": {
"Server": [
"Caddy"
"Location": [
"https://elasticsearch.example.com/"
"Connection": [
"close"
"Content-Type": []
It is generated by
https://elasticsearch.example.com {
reverse_proxy elasticsearch:9200
Is there a way, for a specific site, to either completely disable logs or filter at the level field? (to leave for example everything above info)
I saw some discussion about that feature in Allow certain paths to be skipped in log by tobya · Pull Request #2028 · caddyserver/caddy · GitHub but did not find anything relevant in the documentation.
