How to differentiate http and websockets in caddy file
Hello,
I am trying to reverse proxy using caddy. The web server uses http and websockets.
http to serve a webpage and websockets for data exchange.
I am getting the webpage to load securely but websockets is not working when activating widgets on the webpage. I am new to servers & networking.
I think the problem is I don’t know how to let caddy know the difference between the two protocols. If I place a different endpoint in the caddy file for websockets everything on the webpage disappears ie. test.boulderhill.xyz/foo/*
I am not getting any error messages but when i activate an action on via the webpage there is no activity in caddy which will normally give me a response code of 200 when things are good.
I am using caddy version 2.73
linux ubuntu 20.04
caddy run, caddy fmt --overwrite, caddy reload
	http_port 80
	https_port 443
test.boulderhill.xyz {
	reverse_proxy / 192.168.1.9:80
	header Connection *Upgrade*
	header Upgrade websocket
	reverse_proxy / 192.168.1.9:81
Read about request matchers: Request matchers (Caddyfile) — Caddy Documentation There’s an example in there specifically about matching websocket requests.
You don’t need these, they’re redundant.
Using a / matcher means to match only exactly / and nothing else, so only requests to the root of your site. Remove it to match everything.
You can’t have two site blocks with the same addresses. That’s a logic error.
Thanks for the quick response.
So with your help it’s working.
The Caddyfile now looks like this:
test.boulderhill.xyz:8081 {
reverse_proxy 192.168.1.9:81
I had to open up port 8081 on my router for websocket traffic and change the javascript
in my html file from
Socket = new WebSocket(‘ws://’ + window.location.hostname + ‘:81/’);
to
Socket = new WebSocket(‘wss://’ + window.location.hostname + ‘:8081/’);
The internal url is a microcontroller that interfaces with the physical environment and was
presented to only work over a local network.
I definitely need to learn more about Caddy and how it works.
Thanks for your help
You could just do this:
	@websockets {
	reverse_proxy @websockets 192.168.1.9:81
	reverse_proxy 192.168.1.9:80
Then you don’t need to override the port, and just do: new WebSocket('wss://' + window.location.hostname);
