How to debug all caddy steps?
I have a Caddyfile and it is not behaving as I would expect. Clearly I am doing something stupid, but the simple logging I get from Caddy isn’t making it obious to me.
I’ve added this to my logging:
	output stderr
	level DEBUG
	format console
But I really want debug logging on all the steps / routing that Caddy does when it gets a request.
Is there a way to do that?
I think I’m looking for something like a caddy trace.
Here is an example of a “route” that isn’t behaving as I would expect. I want a 404, but am gettign a status 0.
❯ sudo caddy run --watch
2024/01/18 17:51:40.018 INFO    using adjacent Caddyfile
2024/01/18 17:51:40.021 INFO    admin   admin endpoint started  {"address": ":2020", "enforce_origin": false, "origins": ["//:2020"]}
2024/01/18 17:51:40.022 WARN    admin   admin endpoint on open interface; host checking disabled        {"address": ":2020"}
2024/01/18 17:51:40.022 INFO    tls.cache.maintenance   started background certificate maintenance      {"cache": "0x40001dca00"}
2024/01/18 17:51:40.023 INFO    http.log        server running  {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/01/18 17:51:40.023 INFO    autosaved config (load with --resume flag)      {"file": "/root/.config/caddy/autosave.json"}
2024/01/18 17:51:40.024 INFO    serving initial configuration
2024/01/18 17:51:40.025 INFO    watcher watching config file for changes        {"config_file": "Caddyfile"}
2024/01/18 17:51:40.030 WARN    tls     storage cleaning happened too recently; skipping for now        {"storage": "FileStorage:/root/.local/share/caddy", "instance": "a17a05a9-f18d-473b-b66f-5a5130b00643", "try_again": "2024/01/19 17:51:40.030", "try_again_in": 86399.999999444}
2024/01/18 17:51:40.030 INFO    tls     finished cleaning storage units
2024/01/18 17:51:49.407 INFO    http.log.access.log0    handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "60358", "client_ip": "127.0.0.1", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:81", "uri": "/bogus", "headers": {"User-Agent": ["curl/7.88.1"], "Accept": ["*/*"]}}, "bytes_read": 0, "user_id": "", "duration": 0.000006704, "size": 0, "status": 0, "resp_headers": {"Server": ["Caddy"]}}
Raspbian: Linux pi5-seattle 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (2023-11-24) aarch64 GNU/Linux
sudo apt install caddy
	admin :2020 # 2019 is in use
:81 {
		output stderr
		level DEBUG
		format console
	handle /ha {
		redir http://pi-seattle:8123/dashboards-all/Overview 302
	handle_errors {
		rewrite * /404.html
		templates
On the line before or after your admin :2020, put debug. That enables debug mode. It’s a shorthand for doing what you’re already doing in your log directive, but for the process logs.
The log directive is only for access logs, which don’t emit debug logs currently.
