How to convert nginx to Caddyfile
1. My Caddy version (caddy version): v1
Laradock - caddy
Ubuntu 18.04 sv
docker-compose up -d caddy
Dockerfile
FROM abiosoft/caddy:no-stats
CMD ["--conf", "/etc/caddy/Caddyfile", "--log", "stdout", "--agree=true"]
EXPOSE 80 443 2015
# Docs: https://caddyserver.com/docs/caddyfile
domain.test:443 {
    root /var/www/public
    fastcgi / php-fpm:9000 php {
        index index.php
    # To handle .html extensions with laravel change ext to
    # ext / .html
    rewrite {
        to {path} {path}/ /index.php?{query}
    gzip
    browse
    log /var/log/caddy/access.log
    errors /var/log/caddy/error.log
    # Uncomment to enable TLS (HTTPS)
    # Change the first list to listen on port 443 when enabling TLS
    tls self_signed
    # To use Lets encrpt tls with a DNS provider uncomment these
    # lines and change the provider as required
    #tls {
    #  dns cloudflare
admin.codeky.test:443{
    root /var/www/admin/dist
    ext / .html
    rewrite {
        to {path} /
    gzip
    browse
    tls self_signed
    proxy /api https://domain.test {
I cannot send a request to https://domain.test via proxy.
I am using ant design pro, the proposed nginx configuration
server {
    listen 80;
    # gzip config
    gzip on;
    gzip_min_length 1k;
    gzip_comp_level 9;
    gzip_types text/plain application/javascript application/x-javascript text/css application/xml text/javascript application/x-httpd-php image/jpeg image/gif image/png;
    gzip_vary on;
    gzip_disable "MSIE [1-6]\.";
    root /usr/share/nginx/html;
    location / {
        # 用于配合 browserHistory使用
        try_files $uri $uri/ /index.html;
        # 如果有资源,建议使用 https + http2,配合按需加载可以获得更好的体验
        # rewrite ^/(.*)$ https://preview.pro.ant.design/$1 permanent;
    location /api {
        proxy_pass https://ant-design-pro.netlify.com;
        proxy_set_header   X-Forwarded-Proto $scheme;
        proxy_set_header   X-Real-IP         $remote_addr;
server {
  listen 443 ssl http2 default_server;
  # 证书的公私钥
  ssl_certificate /path/to/public.crt;
  ssl_certificate_key /path/to/private.key;
  location / {
  location /api {
      proxy_set_header   Host              $http_host;
I tried many ways to turn to caddy, but without success
https://pro.ant.design/docs/deploy
What’s stopping you from sending this request, exactly?
I’m not sure what the cause is, but when sending a request to admin.codeky.test/api/xxx will not switch to codeky.test/api/xxx, with the nginx configuration above, everything works, but I tried with caddy proxy does not work.
Sounds like you can send a request just fine but don’t get the result you’re expecting?
Can you post the results from running curl -IL admin.codeky.test/api/xxx?
Can you elaborate a little on what exactly the result should be for such a request?
