How to configure Caddy with internal intermedia CA signed by AD CS?
Hello
1. Output of caddy version:
systemctl start the service
Ubuntu Focal
caddy reload --config /etc/caddy/Caddyfile
  	pki {
  		ca internalca {
  			name "Caddy Intermediate CA"
  			root {
  				cert /etc/caddy/caddy.crt.pem
  				key /etc/caddy/caddy.key.pem
  				format pem_file
  https://portainer.corp.example.com {
  	reverse_proxy https://pilot.corp.example.com:9443
I’m simply trying to setup Caddy to use an intermediate CA signed by our AD CS.
The key and cert are already existing and signed
We are using Caddyfile so far
And I cannot find any complete documentation about:
  • how to completely configure Caddy TLS to use a specific keypair
  • how to automated TLS in Caddyfile and not in JSON
I’ve read what I could mixing some doc using the JSON format, some others the Caddyfile one. Documentation related to both format don’t always present the same options…
So my question as someone who started to use Caddy 2 hours ago is: what am I supposed to do to run a pretty classic and simple config for internal use with Caddy having its own Intermediate CA signed by AD CS?
You’ll need to enable the internal issuer for your site to make it use the CA you configured.
	pki {
		ca internalca {
			root {
				format pem_file
		internal {
			ca internalca
If you don’t give a name to your custom CA (i.e. leave it default) then you can shorten the config in your site to just tls internal.
Or you can use the local_certs global option to make all sites use the default internal CA.
Thanks! It’s getting better!
Additional question: how should I add the CA chain? My /etc/caddy/caddy.crt.pem was supposed to be the Caddy CA, actually it create another intermediate one create by that intermediate. Why not.
But how can I add here the public key (only) of my Root CA (the AD CS one) to add to the chain?
Or is it possible to do something like that?
			root {
				cert /etc/caddy/adcs.crt.pem
			intermediate {
				format pem_file
I guess you can use the sign_with_root option.
We might not have covered that usecase (i.e. no access to root key). Not sure if that’s even possible with the underlying lib we use (Smallstep). We’ll have to look into that later.
