How to Configure Caddy with Cloudflare Tunnel and Ghost CMS in Docker Setup?
I’m trying to configure Caddy with Cloudflare Tunnel and Ghost CMS. Caddy is part of the Ghost self-host Docker setup. The Docker containers for this configuration are running inside an Ubuntu server VM on a small dedicated server in my local network. The Cloudflare container is running on a separate VLAN. The server VLAN is configured to allow all traffic on all ports to the Ghost CMS VM IP.
I have a domain configured with Cloudflare to connect to an app on a Docker host VM on the same server. The configuration is very simple. For example, Immich is accessed through https://immich.mydomain.com. In this case, I point the Cloudflare Tunnel to http://local-vm-ip:immich-port.
For the Ghost CMS instance, it doesn’t work that way. Caddy is required for Ghost to provide full functionality, so I can’t remove Caddy from the configuration.
I tried pointing the Cloudflare route ghost.mydomain.com to https://local-vm-ip, but it simply doesn’t work. I get a 502 response when I curl https://ghost.mydomain.com.
Below are the Docker Compose file, Caddy config file, and .env file examples.
$: curl -I https://ghost.xxxxxxxxx.xxx
HTTP/2 502
date: Sun, 01 Feb 2026 00:12:35 GMT
content-type: text/plain; charset=UTF-8
content-length: 15
cache-control: private, max-age=0, no-store, no-cache, must-revalidate, post-check=0, pre-check=0
expires: Thu, 01 Jan 1970 00:00:01 GMT
referrer-policy: same-origin
x-frame-options: SAMEORIGIN
server: cloudflare
cf-ray: 9c6d3cf31fb26af7-SJC
alt-svc: h3=":443"; ma=86400
image: caddy:2.10.2-alpine@sha256:953131cfea8e12bfe1c631a36308e9660e4389f0c3dfb3be957044d3ac92d446
Caddy is part of the docker self-host configuration provided by ghost cms
docker compose up
# yaml-language-server: $schema=https://raw.githubusercontent.com/compose-spec/compose-spec/main/schema/compose-spec.json
    restart: always
      DOMAIN: ${DOMAIN:?DOMAIN environment variable is required}
      ADMIN_DOMAIN: ${ADMIN_DOMAIN:-}
      ACTIVITYPUB_TARGET: ${ACTIVITYPUB_TARGET:-https://ap.ghost.org}
      - ./caddy:/etc/caddy
      - caddy_data:/data
      - caddy_config:/config
    depends_on:
      - ghost
      - ghost_network
  ghost:
    # Do not alter this without updating the Tinybird Sync container as well
    image: ghost:${GHOST_VERSION:-6-alpine}
    restart: always
    # This is required to import current config when migrating
    env_file:
      - .env
      NODE_ENV: production
      url: https://${DOMAIN:?DOMAIN environment variable is required}
      admin__url: ${ADMIN_DOMAIN:+https://${ADMIN_DOMAIN}}
      database__client: mysql
      database__connection__host: db
      database__connection__user: ${DATABASE_USER:-ghost}
      database__connection__password: ${DATABASE_PASSWORD:?DATABASE_PASSWORD environment variable is required}
      database__connection__database: ghost
      tinybird__tracker__endpoint: https://${DOMAIN:?DOMAIN environment variable is required}/.ghost/analytics/api/v1/page_hit
      tinybird__adminToken: ${TINYBIRD_ADMIN_TOKEN:-}
      tinybird__workspaceId: ${TINYBIRD_WORKSPACE_ID:-}
      tinybird__tracker__datasource: analytics_events
      tinybird__stats__endpoint: ${TINYBIRD_API_URL:-https://api.tinybird.co}
      - ${UPLOAD_LOCATION:-./data/ghost}:/var/lib/ghost/content
    depends_on:
      db:
        condition: service_healthy
      tinybird-sync:
        condition: service_completed_successfully
        required: false
      tinybird-deploy:
        required: false
      activitypub:
        condition: service_started
        required: false
      - ghost_network
  db:
    image: mysql:8.0.44@sha256:f37951fc3753a6a22d6c7bf6978c5e5fefcf6f31814d98c582524f98eae52b21
    restart: always
    expose:
      - "3306"
      MYSQL_ROOT_PASSWORD: ${DATABASE_ROOT_PASSWORD:?DATABASE_ROOT_PASSWORD environment variable is required}
      MYSQL_USER: ${DATABASE_USER:-ghost}
      MYSQL_PASSWORD: ${DATABASE_PASSWORD:?DATABASE_PASSWORD environment variable is required}
      MYSQL_DATABASE: ghost
      MYSQL_MULTIPLE_DATABASES: activitypub
      - ${MYSQL_DATA_LOCATION:-./data/mysql}:/var/lib/mysql
      - ./mysql-init:/docker-entrypoint-initdb.d
    healthcheck:
      test: mysqladmin ping -p$$MYSQL_ROOT_PASSWORD -h 127.0.0.1
      interval: 1s
      start_period: 30s
      start_interval: 10s
      retries: 120
      - ghost_network
  traffic-analytics:
    image: ghost/traffic-analytics:1.0.42@sha256:c927127b0e79ef92093ed553a47a26c99693714c94729561ba0bda70eccda8ba
    restart: always
    expose:
      - "3000"
      - traffic_analytics_data:/data
      PROXY_TARGET: ${TINYBIRD_API_URL:-https://api.tinybird.co}/v0/events
      SALT_STORE_TYPE: ${SALT_STORE_TYPE:-file}
      SALT_STORE_FILE_PATH: /data/salts.json
      TINYBIRD_TRACKER_TOKEN: ${TINYBIRD_TRACKER_TOKEN:-}
      LOG_LEVEL: debug
    profiles: [analytics]
      - ghost_network
  activitypub:
    image: ghcr.io/tryghost/activitypub:1.1.0@sha256:39c212fe23603b182d68e67d555c6b9b04b1e57459dfc0bef26d6e4980eb04d1
    restart: always
    expose:
      - "8080"
      - ${UPLOAD_LOCATION:-./data/ghost}:/opt/activitypub/content
      # See https://github.com/TryGhost/ActivityPub/blob/main/docs/env-vars.md
      MYSQL_HOST: db
      MYSQL_DATABASE: activitypub
      LOCAL_STORAGE_PATH: /opt/activitypub/content/images/activitypub
      LOCAL_STORAGE_HOSTING_URL: https://${DOMAIN}/content/images/activitypub
    depends_on:
      db:
      activitypub-migrate:
    profiles: [activitypub]
      - ghost_network
  # Supporting Services
  tinybird-login:
    build:
      context: ./tinybird
      dockerfile: Dockerfile
    working_dir: /home/tinybird
    command: /usr/local/bin/tinybird-login
      - tinybird_home:/home/tinybird
      - tinybird_files:/data/tinybird
      - ghost_network
    tty: false
    restart: no
  tinybird-sync:
    # Do not alter this without updating the Ghost container as well
    command: >
      sh -c "
        if [ -d /var/lib/ghost/current/core/server/data/tinybird ]; then
          rm -rf /data/tinybird/*;
          cp -rf /var/lib/ghost/current/core/server/data/tinybird/* /data/tinybird/;
          echo 'Tinybird files synced into shared volume.';
        else
          echo 'Tinybird source directory not found.';
        fi
    depends_on:
      tinybird-login:
      - ghost_network
    restart: no
  tinybird-deploy:
    build:
      context: ./tinybird
    working_dir: /data/tinybird
    command: >
      sh -c "
        tb-wrapper --cloud deploy
    depends_on:
      tinybird-sync:
      - ghost_network
    tty: true
    image: ghcr.io/tryghost/activitypub-migrations:1.1.0@sha256:b3ab20f55d66eb79090130ff91b57fe93f8a4254b446c2c7fa4507535f503662
      MYSQL_DB: mysql://${DATABASE_USER:-ghost}:${DATABASE_PASSWORD:?DATABASE_PASSWORD environment variable is required}@tcp(db:3306)/activitypub
      - ghost_network
    depends_on:
      db:
    restart: no
  caddy_data:
  caddy_config:
  tinybird_files:
  tinybird_home:
  ghost_network:
https://{$DOMAIN}:443 {
	import snippets/Logging
	# Traffic Analytics service
	import snippets/TrafficAnalytics
	# ActivityPub Service
	import snippets/ActivityPub
	# Default proxy everything else to Ghost
		reverse_proxy ghost:2368
	# Optional: Enable gzip compression
	# Optional: Add security headers
	import snippets/SecurityHeaders
# Separate admin domains
# To use a separate domain for Ghost Admin uncomment the block below (recommended)
# {$ADMIN_DOMAIN} {
# 	import snippets/Logging
# 	# Traffic Analytics service
# 	import snippets/TrafficAnalytics
# 	# ActivityPub Service
# 	import snippets/ActivityPub
# 	# Default proxy everything else to Ghost
# 	handle {
# 		reverse_proxy ghost:2368
# 	# Optional: Enable gzip compression
# 	encode gzip
# 	# Optional: Add security headers
# 	import snippets/SecurityHeaders
# Redirect www -> root domain
# To redirect the www variant of your domain to the non-www variant uncomment the 4 lines below
# Note: You must have DNS setup correctly for both domains for this to work
# www.{$DOMAIN} {
# 	redir https://{$DOMAIN}{uri}
# Redirect root -> www domain
# To redirect the non-www variant of your domain to the www variant uncomment the 4 lines below and change CHANGE_ME to your root domain
# When using ActivityPub with a www. domain, you must enable this redirect for ActivityPub to work correctly
# CHANGE_ME {
