How to Configure a Caddy Reverse Proxy to Allow Access to Network Devices
I recently installed Candy on my Ubuntu machine. I need assistance setting up a reverse proxy so that I may access my network devices via secure HTTPS. In my network, I have switches and access points, and each device is mapped through a private address, such as 10.10.0.0, and we are currently accessing all of the devices via browser and receiving a not secured symbol. I want to use the caddy server to secure this so that everytime we access any device, it shows a secure icon rather than not being secured with a correct certificate. Can somebody tell me how I can accomplish this and set up the caddy file?
I installed Caddy on my Ubuntu PC using the URL provided below.
Ubuntu 20.04.6 LTS
I installed caddy using the commands shown below.
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/gpg.key’ | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt’ | sudo tee /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install caddy
The Caddyfile is an easy way to configure your Caddy web server.
Unless the file starts with a global options block, the first
uncommented line is always the address of your site.
To use your own domain name (with automatic HTTPS), first make
sure your domain’s A/AAAA DNS records are properly pointed to
this machine’s public IP, then replace “:80” below with your
domain name.
firewall.localhost
    root * /usr/share/caddy
@matt Can you please help on this, if possible.
I glanced at this a few days ago, but the help template is missing sections and not really readable, so I can’t make heads or tails of the post. If you could revise.your post to fill out the help template and make it look nice it’ll be easier to follow what’s going on. I’m not really sure how to connect the dots as-is.
Recently installed Candy on my Ubuntu machine. I need assistance setting up a reverse proxy so that I may access my network devices via secure HTTPS. In my network, I have switches and access points, and each device is mapped through a private address, such as 10.10.0.0, and we are currently accessing all of the devices via browser and receiving a not secured symbol. I want to use the caddy server to secure this so that everytime we access any device, it shows a secure icon rather than not being secured with a correct certificate. Can somebody tell me how I can accomplish this and set up the caddy file?
@matt Please help.
There is no error because first I need a information how I can achieve above requirement using Caddy file.
sudo apt update
Ubuntu 20.04.6 LTS
caddy run and sudoedit /etc/caddy/Caddyfile
reverse_proxy 10.10.10.10:80.
Make sure your syntax is correct. The period at the end there will cause an error.
The help template has instructions for showing requests that aren’t working that you expect to be working. Please show us curl commands because that will help us know what you are trying to do and exactly what errors you are getting.
So you haven’t even tried running your Caddy config yet?
Hi,
Thanks for your reply. No, I am unable to configure my caddy file since I am unsure how I will meet my requirements and how the caddy file should be configured. I did some research and made some adjustments to the caddy file yesterday, but it is still not working. If you look at my caddy file configuration below, you will notice that I have entered three local IP addresses, two of which are running on the same ports, 443. Currently, all of my devices utilize self-signed certificates, but I’m considering of centralizing management with caddy proxy. That is, I want all of my devices to receive certificates from caddy rather than self-signed certificates.
Error messages and/or full log output:
idfyinfra@LA-255:~$ systemctl status caddy.service
● caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2023-07-11 11:29:27 IST; 18s ago
Docs: Welcome — Caddy Documentation
Process: 3076 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 3076 (code=exited, status=1/FAILURE)
Jul 11 11:29:27 LA-255 caddy[3076]: LOGNAME=caddy
Jul 11 11:29:27 LA-255 caddy[3076]: USER=caddy
Jul 11 11:29:27 LA-255 caddy[3076]: INVOCATION_ID=346b67884cce43b4ba3c41d086ad671d
Jul 11 11:29:27 LA-255 caddy[3076]: JOURNAL_STREAM=8:58777
Jul 11 11:29:27 LA-255 caddy[3076]: {“level”:“info”,“ts”:1689055167.163001,“msg”:“using provided configuration”,“config_file”:“/etc/caddy/Caddyfile”,“config_adapter”:“”}
Jul 11 11:29:27 LA-255 caddy[3076]: {“level”:“warn”,“ts”:1689055167.1633763,“logger”:“caddyfile”,“msg”:“Using a path in a site address is deprecated; please use the ‘handle’ directive instead”,“address”>
Jul 11 11:29:27 LA-255 caddy[3076]: Error: adapting config using caddyfile: hostname appears in more than one automation policy, making certificate management ambiguous: *
Jul 11 11:29:27 LA-255 systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jul 11 11:29:27 LA-255 systemd[1]: caddy.service: Failed with result ‘exit-code’.
Jul 11 11:29:27 LA-255 systemd[1]: Failed to start Caddy.
My complete Caddy config:
172.16.13.20 {
reverse_proxy 10.10.10.10:443
reverse_proxy 10.10.10.1:17322
reverse_proxy 10.10.20.10:443
Remarks:
172.16.13.20 - This is the IP address of the server where caddy server is installed.
@matt Have you had the chance to review?
@francislavoie Not sure, but perhaps you could check into this and assist us in configuring the Caddy file. Because you all have a lot of experience.
This is telling caddy to revers proxy the request to 172.16.13.20 to three different backends. This will certainly cause errors. You cannot forward and IP to multiple backends with the same port. For that you need to use domains. This would be an example…
server1.homedomain.com {
     reverse proxy 10.10.10.10:43
server2.homedomain.com {
     reverse proxy 10.1.10.1:17322
server3.homedomain.com {
     reverse proxy 10.10.20.10:443
You would also need to make sure that all these domains resolve to your caddy IP.
