1. Output of caddy version:
www.tigerice.cn {
route /merchant/* {
uri strip_prefix /merchant
file_server {
root /opt/twomicro_v2/web/merchant
browse
disable_canonical_uris
file_server * {
root /var/www/html
reverse_proxy /nacos {
to http://127.0.0.1:8848
CentOS7
systemctl start caddy
# caddy.service
# for your installation.
Type=notify
www.tigerice.cn {
route /merchant/* {
file_server {
browse
file_server * {
root /var/www/html
how to change nginx proxy config to caddy
nginx proxy
location /nacos {
proxy_pass http://127.0.0.1:8848/nacos;
caddy proxy
curl -v https://www.tigerice.cn/nacos/
reverse_proxy
curl -v https://www.tigerice.cn:8848/nacos/
how to config!
